September 16, 2026, 04:28:37 am
Hoffman Amps Forum image Author Topic: jcm 900 slx 50w issues  (Read 5503 times)
Offline 961le
  • RIP 12-11-2008
« on: August 27, 2011, 02:21:24 pm »
just recently after playing my amp for a while, the volume will fade away with a fuzz sound and will then come back to normal volume, this occurs every few minutes. a little background... the amp is a 93 model and i need to replace the caps asap. my question is: will the old caps cause this situation? or, are there more issues under the surface? when its at volume it sounds quite lovely :)
Re: jcm 900 slx 50w issues
« Reply #1 on: August 27, 2011, 02:29:59 pm »
First suspect, with no other information: Yes, the electrolytic caps in the power supply are getting senile in their old age.
« Reply #2 on: August 28, 2011, 01:54:24 am »
Give your effects loop jack a workout with a plug and some cleaner, maybe re-tension the contact shunt leg if it looks loose.  Try the easy stuff first!
Are you sure the caps are bad?
Good luck!
Offline 961le
  • RIP 12-11-2008
« Reply #3 on: August 28, 2011, 03:52:41 pm »
richie, in the past i have had issues with the effects loop. only after i had tampered with it. after a few jabs all was well. the bassy notes usually taper off with a little fuzz in the background. im about to order some f&t's and see what happens. this little sucker gets a lot of bad wrap, but when dialed in its very nice:) ill report back.
Offline 961le
  • RIP 12-11-2008
« Reply #4 on: August 30, 2011, 08:43:05 pm »
well the answer is yes, bad caps will cause my problems. after i had them removed i checked their capacitance and both were within spec.  at that point i was wishing i had left it alone but i proceded anyway. after the swap the change was very noticable. it sounds wonderful, nice and tight. now after looking at the board mounted caps i was wondering if i should tackle those next? where do you source pcb components? thanks for the replys guys.
