September 16, 2026, 10:39:41 am
Hoffman Amps Forum image Author Topic: 2204 SE done!  (Read 10484 times)
Offline Madison
  • What's up slobbies?
    • Funky Dolphins
2204 SE done!
« on: August 28, 2011, 12:56:41 am »
Here it is.
The "PLXSE"
Little gain monster!
I don't think I would want any more gain.
It's over the top with a LP;have to turn down the preamp a bit.
With a Strat or Tele it's just about right.
Really sounds good with my old Charvelle metal beast guitar.
It's got a 8" speaker in it to make it compact.I think a 10" could fit with some finagling.
VVR is surprisingly good!
Thanks for all the tips, ideas, and sharing your wealth of knowledge.
I'm not worthy :worthy1:
Re: 2204 SE done!
« Reply #1 on: August 28, 2011, 03:27:47 am »
NICE :thumbsup:
Offline LooseChange
    • Fix Your Darn Amps
Re: 2204 SE done!
« Reply #2 on: August 28, 2011, 06:05:19 am »
Nice looking amp!
Call me Dan
www.fydamps.com
Re: 2204 SE done!
« Reply #3 on: August 28, 2011, 06:18:53 am »
Absolutely beautiful!  I love your wood cab. Very very nice job with it. I'm impressed!
Offline jeff
  • Need input
Re: 2204 SE done!
« Reply #4 on: August 28, 2011, 10:25:22 am »
Nice. I'm just a little curious about part of your circuit. The fourth tube sections grid leak resistor is connected to the third tubes cathode. What does this do? I'm used to seeing that 470K resistor going to ground. Doesn't this put a positive voltage on the forth tubes grid? What's the voltage on the forth tubes grid and forth tubes cathode?
Re: 2204 SE done!
« Reply #5 on: August 28, 2011, 10:27:22 am »
Nice! I'm humbled by the woodwork!
Re: 2204 SE done!
« Reply #6 on: August 28, 2011, 10:44:06 am »
Very, very clean, nice build! Impressive woodworking there. Well done!
Offline Leevi
    • Rikstone
Re: 2204 SE done!
« Reply #7 on: August 28, 2011, 10:47:00 am »
Great work! The circuit looks interesting, thank you for sharing that.
/Leevi
Re: 2204 SE done!
« Reply #8 on: August 28, 2011, 11:15:18 am »
 :m11 :m11
Offline CraigB
Re: 2204 SE done!
« Reply #9 on: August 28, 2011, 12:14:42 pm »
Love the cabinet, beautiful!
Offline punkykatt
Re: 2204 SE done!
« Reply #10 on: August 28, 2011, 01:03:49 pm »
WOW!!! some great talent on this forum. Beautiful job.
Offline TubeGeek
    • Glacier Amps
Re: 2204 SE done!
« Reply #11 on: August 28, 2011, 01:48:12 pm »
 :headbang:
Nice job!
Offline topbrent
Re: 2204 SE done!
« Reply #12 on: August 29, 2011, 01:06:17 am »
Well done!
I bet that would sound awesome through a 4x12 cab.
Offline punkykatt
Re: 2204 SE done!
« Reply #13 on: August 29, 2011, 07:27:01 am »
Madison, how did you make that tube chart? Punky
Offline Fresh_Start
  • noob de Lux
Re: 2204 SE done!
« Reply #14 on: August 29, 2011, 10:56:38 pm »
Really nice work!  Just the cab looks great.  Any gut shots?
IRRC what you're looking at actually is local feedback around the 3rd gain stage.  Depending on voltages, the 4th stage probably is biased relatively "hot".  Madison, can you post voltages?  Especially the 3rd stage cathode & plate, and cathode and grid of 4th stage?
Jeff - I can tell you that Madison faithfully followed a proven circuit.
Madison - is your feedback resistor really 1.5K, not 15K?  Seems like a much larger percentage of NFB than the circuit you started with.  Also, how did you come up with 56K for the power tube's grid return resistor?  The base circuit had a 250K Master Volume pot there.  I understand why VVR replaces the MV, just wondering about the relatively low value for the grid return resistor.
Most importantly - does this meet the customer's needs/wants?
Thanks for sharing your work,
Chip
Quote from: jjasilli
Quote from: PRR
Offline zendragon63
  • Vacuum Packed Tone
Re: 2204 SE done!
« Reply #15 on: August 29, 2011, 11:57:37 pm »
Nice woodworking Madison! You might consider a cover if you pack it around any; nice woodwork like that gets dinged up much easier and often than you might think (I know this!). Regards
dennis
Knowledge is what you get when you read the fine print; experience is what get when you don't. I am, therefore, experienced.
Online sluckey
Re: 2204 SE done!
« Reply #16 on: August 30, 2011, 05:52:59 am »
Punky, I used Visio to make these old Fender style tube charts. These are totally made inside Visio but you can easily put any image onto the chart.
Re: 2204 SE done!
« Reply #17 on: August 30, 2011, 11:46:54 am »
Good stuff Madison! You got this done pretty fast!
Offline phsyconoodler
Re: 2204 SE done!
« Reply #18 on: August 30, 2011, 12:09:03 pm »
That looks killer! Very nice work!
  Any chance we could see the guts?
Offline weege
Re: 2204 SE done!
« Reply #19 on: August 31, 2011, 01:05:05 am »
Would you be so kind as to explain how the chassis is mounted?   :dontknow:
Offline Madison
    • Funky Dolphins
Re: 2204 SE done!
« Reply #20 on: August 31, 2011, 07:51:27 am »
1st off, thanks!
Seriously, this would not be possible without Mr. Hoffman's generosity and the gang.
I found a few on the net and I think Steve was nice enough to share his with me way back.
Then I went into Fireworks (like Photoshop) and decided to make my own to get really clean hi rez to manipulate.
Chip covered it, thank goodness!
I kind of get the concept but not skilled technically enough to explain it as eloquently as he did!
No time to.It's gone.
Dumb, I know all about it.
1.5K was a happy medium for me
YMMV.
Circuit didn't like going above that level.
Me thinks so.No news is good news round these parts.
 >>Any chance we could see the guts?
This thing went though a bunch of changes.Flat out odd bizarre layout in some places.
But, it sounded great!(for that sort of sound)
It was also dead quiet.
I have enough stuff laying around,I think I will make a 6v6 head for myself.
That one will be perfect and I'll share.
I rolled my own chassis on this one.(I don't recommend it but I did it for kicks).
The front, bottom, and,rear 1 piece of aluminum bent to a "U".
The sides are wood.
The 4 cab cleats support the underside of the chassis.
The speaker baffle has a lip to keep the chassis from falling out the front.
The rear panel is about 1/2 inch thick and the top 2 screws thread into the chassis.
The tolerances are tight!
It's a lot of work.
I''d suggest chassis straps if you are in a hurry and plan REALLY well where to drill.
Miller time.
Peace all.
« Last Edit: August 31, 2011, 10:35:33 pm by Madison »
