September 16, 2026, 04:23:04 pm
Hoffman Amps Forum image Author Topic: Which pot do you use for VVR ? - Which are good product for this use ?  (Read 4945 times)
Kagliostro
stratele52
  • Guest
Re: Which pot do you use for VVR ? - Which are good product for this use ?
« Reply #1 on: August 31, 2011, 04:32:21 pm »
Sorry , but what is VVR ?
Offline VMS
« Reply #2 on: August 31, 2011, 04:52:15 pm »
If I were to try VVR, I would probably use this one:
http://www.banzaimusic.com/PEC-MIL-MO-LIN-1M.html
Offline FYL
« Reply #3 on: August 31, 2011, 06:36:06 pm »
Any pot rated at 500 V or more is OK. I prefer to use Mil-spec 2 W models from Clarostat, PEC or Sfernice which offer a better safety margin and are more reliable.
« Reply #4 on: September 01, 2011, 01:59:22 am »
Many thanks VMS - FYL
what is VVR ?
VVR = Variable Voltage Regoulator
usually used to scale the B+ voltage of PI and Power Tubes to achieve overdrive sound also at low power output levels
may be used also to reduce the the voltage only to the Power Tubes, or to the complete amp, but this way of reduction are less used.
Here a thread about VVR
http://www.el34world.com/Forum/index.php?topic=6899.0
Kagliostro
