September 16, 2026, 04:21:54 pm
Hoffman Amps Forum image Author Topic: voltages on a schematic  (Read 4779 times)
Offline dude
« on: September 01, 2011, 10:58:50 am »
When voltages are posted on a schematic are they with or without tubes.
I know maybe a stupid question, without tubes some points won't have voltage.
al
Re: voltages on a schematic
« Reply #1 on: September 01, 2011, 11:05:19 am »
Schematic voltages are stated with tubes in = loaded.  This is true generally -- that voltage is stated under load.
Offline stingray_65
« Reply #2 on: September 01, 2011, 02:52:08 pm »
By load JJasilli means tubes in sockets, NOT under load with a signal present.
Always have a speaker or dummy load plugged in also.
While it would not hurt if no signal was present to not have a speaker installed, there is a chance that oscillation may occur, then send a signal through the amp and the OT will likely suffer.
I was often confused myself until I asked.
Ray
PS, Don't forget, you got a + or - 20% tolerance on those stated values. eg. if the schemo states 100V, 80 to 120 V is acceptable.
The only place I REALLY try to keep dead center is the 6.3V heater supply.
« Last Edit: September 01, 2011, 02:55:40 pm by stingray_65 »
stratele52
  • Guest
« Reply #3 on: September 01, 2011, 02:58:19 pm »
Yes with all tubes AND proper bias. No signal at the input . Voltage can vary to 10 %.
A colder bias will gave you more voltage specialy at the output tubes plate and center tap of power transformer / power supply. A very very hot bias = lower voltage.
