September 19, 2026, 12:10:26 am
Hoffman Amps Forum image Author Topic: Timbo's tubes and mosfets  (Read 5758 times)
« on: September 08, 2011, 07:00:01 am »
I saw that Timbo had posted this under solid state but since it's definitely amp designing and using tubes in the circuitry, I wanted to reference what he shared here so others would be sure to see it.  He shares how to use mosfets to add reverb and vibrato to a tube amp.  That could be useful if there is limited space.
http://www.el34world.com/Forum/index.php?topic=12259.new#new
With respect, tubenit
Re: Timbo's tubes and mosfets
« Reply #1 on: September 08, 2011, 02:26:58 pm »
Hi guys, Here's the link where i found it (interesting amp) was also hoping to find a mosfet active loop but so far nothing (maybe they don't work that way  :think1:)I had thoughts that this loop circuit could be a good candidate because when turned on (with nothing plugged in)it only slightly adds gain  :dontknow: Hope the more SS savvy can help.Thanks
http://www.blueguitar.org/new/articles/other/mikede30.pdf
« Last Edit: September 08, 2011, 02:30:58 pm by TIMBO »
Offline Fresh_Start
  • noob de Lux
« Reply #2 on: September 09, 2011, 10:31:53 am »
TIMBO - thanks for that link!  Interesting circuit.  I hadn't thought of injecting tremolo that way for a cathode biased amp.  Any downside that you know of?
Cheers,
Chip
Quote from: jjasilli
Quote from: PRR
« Reply #3 on: September 09, 2011, 11:49:16 am »
Interesting that he used jfets on the mosfet sources like that. I wonder whether you could get away with just using IRF820s as a straight sub for a triode stage with drain going to (what would otherwise be) the plate connection, gate to the grid connection, and source to the cathode connection. I see he has the gate reverse-biased with a zener and bypass cap and the jfet hooked up (like some kind of voltage regulator?) to give the source voltage the same way you'd get a cathode voltage in a triode stage. Is that just a belt and braces approach? Or is there some other wisdom for that? (I guess I don't really understand SS stuff that well)
Offline Fresh_Start
  • noob de Lux
« Reply #4 on: September 09, 2011, 12:38:32 pm »
Google "MOSFET Follies" for R. G. Keen's take on replacing tube triodes with MOSFETs.
HTH
Chip
Quote from: PRR
« Reply #5 on: September 09, 2011, 01:37:13 pm »
Many thanks for sharing the link Timbo & Tubenit
Kagliostro
