September 21, 2026, 04:53:28 pm
Hoffman Amps Forum image Author Topic: Weird Phase inverter...  (Read 5163 times)
« on: September 16, 2011, 10:13:11 pm »
e. rondehuis presents an "interesting" phase inverter in his book "valves for audio frequency amplifiers". it's a reprint by the audio amateur press.
the use of heptode is weird enough, but the arrangement kind of baffles me. i wish i had a scanner to scan in the original schematic, but i don't. i redrew the schematic. i hope it is a faithful redux of the original. if you have some time and the spare scratch, pick up a copy of the book; it's a decent read for  novice level builders. it can be obtained from antique electronic supply.
in the plan the designer used an ECH21 for the phase inverter - why, i have NO idea. it's a weird-ass tube - a loktal no less, and the common cathodes are brought out on the locking/guide pin - base is all metal so is the locking in - duh! ;)
http://tubedata.milbert.com/sheets/030/e/ECH21.pdf
what in the sam hell is going on? some sort of long tail with out the tail? common cathodes but biased conventionally? paraphase of the weirdest kind - how about that P3 to "balance" the PI - i'm guessing that's what that's for?
scanning through the text, he makes no mention of what the values are for L1 - the author presents another design example of a 35W EL34 amp w/ similar supply and used the 8H 50mA choke - so snatched the value from that.
much thanks in advance for any enlightenment.
peace.
--DL
Re: Weird Phase inverter...
« Reply #1 on: September 16, 2011, 10:30:26 pm »
Heptode is working like a pentode. Plain gain stage.
Triode is an ordinary floating paraphase. 1Meg+1.1Meg set it up as a unity-gain inverter. The 10% difference accounts for triode gain being closer to 10 than to infinity.
The common cathode network may have to be heavily bypassed to avoid instability.
« Reply #2 on: September 16, 2011, 10:39:22 pm »
'pears to be directly copied from page 5 here?
http://tubedata.tubes.se/sheets/046/u/UCH21.pdf
Same idea but only converter service shown:
http://www.r-type.org/pdfs/6aj8.pdf
« Reply #3 on: September 16, 2011, 11:04:00 pm »
that's what threw me, the shared cathode, nearly all paraphase i've seen don't share cathode.
much thanks PRR, i see what's going on now.  :icon_biggrin:
btw, not something i'd go out my way to build for hi-fi or guitar. it was posted solely for educational enlightenment.
--DL
Offline rzenc
  • TUBES RULE
« Reply #4 on: September 17, 2011, 09:16:29 am »
i'm building - one more  :icon_biggrin: ! - 5E9A, and it is an example of paraphase sharing cathodes.
http://www.el34world.com/charts/Schematics/files/fender/TREMOLUX_5E9A.pdf
Best Regards
rzenc
