September 19, 2026, 03:01:05 am
Hoffman Amps Forum image Author Topic: Ampeg V4B re-issue tube chart  (Read 10631 times)
Offline Tiny_Daddy
  • Get your Amp N Gear!
« on: September 17, 2011, 09:49:29 am »
This amp uses all 12AX7 and one 12AU7 as PI. Problem is, I don't know if this is correct because the tubes are not original. I cannot find a schematic or manual that matches this amp. Should the tube that drives the PI be a 12DW7?
Offline ThermionicEngine
  • ooops- Should have cut the blue wire first
Re: Ampeg V4B re-issue tube chart
« Reply #1 on: September 17, 2011, 10:30:46 am »
If your amp is a V4b reissue (V4H), The PI is a 12AU7.  They did not use the 12DW7 or the compactron tube, or the 7027 for that matter.  The only problem is they used 2 12AU7s, I just don't remember where they used the other one...  I suppose there is no schematic in the cabinet or chassis.  I got half the question answered, anyway...
V= IR; Everything else is derivative...
Offline Bub
« Reply #2 on: September 17, 2011, 02:31:16 pm »
Hope this helps
Rob
Offline Tiny_Daddy
« Reply #3 on: September 17, 2011, 03:16:55 pm »
Thanks, that's the amp. The preamp tubes don't seem to be called out but they are likely both 12AX7.
Offline LooseChange
    • Fix Your Darn Amps
« Reply #4 on: September 17, 2011, 03:18:13 pm »
The chassis is labeled with all the tubes types.
Call me Dan
www.fydamps.com
Offline Tiny_Daddy
« Reply #5 on: September 17, 2011, 03:50:53 pm »
This chassis isn't, I went and looked again. No labels in the cabinet either. Anyone out there with a labeled chassis?
Offline jerrydyer
  • Make it one of a kind
« Reply #6 on: November 16, 2017, 03:44:43 pm »
I havent been here in a while but , im fixing a v4b reissue. Check this out, correct voltages on heaters but tubes will not light up.
HELP
« Reply #7 on: November 16, 2017, 04:12:24 pm »
Maybe you're not measuring the filament voltage correctly. Measure the voltage between the filament pins, not from chassis to one pin and then from chassis to the other pin. IOW, put one meter probe on one filament pin and the other probe on the other filament pin. I bet that will tell a different story.
Offline jerrydyer
« Reply #8 on: November 21, 2017, 03:47:29 pm »
Thank you sir.  Have you dealt with the,reissue,v4b, the one with blackface and colorful v4b.....blue and red?
« Reply #9 on: November 21, 2017, 04:09:54 pm »
no
