September 17, 2026, 01:48:55 am
Hoffman Amps Forum image Author Topic: UL Screen Tap Question...  (Read 8673 times)
« on: September 22, 2011, 10:23:16 pm »
Reading up on UL operation and I have a question.  All the articles I read state that the 6L6/KT88/KT66/etc family "likes" about a 42% plate v tap.  The 6V6 family "likes" about a 23% plate v tap.  Ok, I'll take their word for it.  However, nothing that I have read explains WHY!  Why that percentage and why the difference in tube families? Other than it is figured on a percentage of the impedance - there is no explanation.  If optimal is 40%, what happens if it is 60%? Or 20%?  Can anyone "esplain" to me in plain english what the heck is going on?
Thank you in advance!
Offline spacelabstudio
  • Unable to leave well enough alone
Re: UL Screen Tap Question...
« Reply #1 on: September 23, 2011, 07:57:40 am »
http://en.wikipedia.org/wiki/Ultra-Linear
Apparently gives you characteristics of pentode and triode operation.  As far as how they arrived at the numbers, I'm guessing trial and error.  I wouldn't be surprised if no one has managed to analyze it physically.
Chris
Offline RicharD
    • Toxic Water
« Reply #2 on: September 23, 2011, 09:36:20 am »
As I understand it (and I'm usually wrong), it's got a lot to do with the physical construction of the tube.  Beam Power tubes tend to have a more durable screen and therefore can handle higher voltages better.  True pentodes and tetrodes are happier with a lower screen voltage and therefore the UL tap should be further away from the plate taps.  Tubes such as the 6CD6 call for a screen voltage to be roughly 1/2 of the plate voltage.  They might not even work in a UL configuration.  Hopefully someone in the know will answer this question properly.
« Reply #3 on: September 23, 2011, 09:50:48 am »
Without burning the mid-night oil, that's what I'm thinking.  Take the 6550: http://www.mif.pg.gda.pl/homepages/frank/sheets/135/6/6550A.pdf
Especially good for hi-fi.  In Class AB1 you get only 0.6% Harmonic Distortion with 400V plate; 270V screen at idle.  UL is a good way to get there.  And for mass production, UL also eliminates the cost of filter circuitry, including a choke, for the screens.  May as well put all that iron in one package.
So I'm thinking that design choice in selection of: a) the power tube; and b) the class of bias -- will determine what %-age of plate voltage the UL tap should be.  The goal seems to minimize Harmonic Distortion, and to fine-tune quiescent plate/screen voltage to do so.  But this will not apply if Harmonic Distortion is not an issue, or if it is desirable; then screen & plate voltages can be equal at idle.
However, I would consult the literature.
« Reply #4 on: September 23, 2011, 11:58:39 am »
try the link below. i have not read the whole article... it may or may not contain the information you seek, however, broskie does explain things well.
http://www.tubecad.com/january2000/page3.html
« Reply #5 on: September 23, 2011, 08:31:43 pm »
It's BS. The percent isn't that fussy.
There's the two extreme "UL" conditions:
0% == Pure Pentode, high power output, no damping
100% == Pure Triode, lower power output, good damping
In-between you have a range of in-between possibilities.
There is a study, somewhere, showing that for specific tubes and goals, 25%-60% is in-between triode and pentode, with a slight preference for "43%". But it isn't that fussy. And if you pick different conditions and goals, you'd come up with some other "optimum", still not critical.
6V6 at traditional voltages (250V-300V) is marginal for current. Heavy UL probably trims power a lot. A lesser tap might do better than you'd pick for a fat tube like EL34.
Since the only OTs you can actually buy are 40% or 43%, and that's as good as any other value, it isn't worth asking "WHY?"
If you must do it, you use an additional winding, wound about 40% of the plate winding and fed the lower G2 voltage.
« Reply #6 on: September 23, 2011, 09:33:11 pm »
Why?  Because it's there! :icon_biggrin:  Thanks PRR, that makes sense.  Yeah, all the iron I've seen is 40% so it's a moot point if I was building - I was just trying to figure out how they got there.  And thanks to the rest of you guys for weighing in - I've been to all those sites!
Offline Merlin
« Reply #7 on: September 25, 2011, 03:25:17 am »
I read (though I can't remember where) that the UL tap that results in the greatest power/distortion ratio is closely related to the distance between screen and cathode; valves that have the screen closer to the anode naturally want a UL tap closer to the anode, and vice versa.
Plausible, but I don't know whether to believe it.
« Reply #8 on: September 25, 2011, 05:33:11 am »
PRR do you mean like this ?
Kagliostro
« Reply #9 on: September 26, 2011, 12:47:39 am »
> related to the distance between screen and cathode; ...Plausible, but I don't know whether to believe it.
The form of the problem suggests a ratio, not a pure "distance".
It's late. I'm not thinking. But a triode has good (certain assumptions) balance of power and gain when Mu is 4 or 5. 6L6 EL34 and kin have Mu of 10. 42% of 10 is 4.2, a good Mu. But I can't convince myself that 42% of Mu is the right answer.
Offline Merlin
« Reply #10 on: September 26, 2011, 04:08:37 am »
You know perfectly well what I mean. If you want to be pedantic, "100% times the screen-cathode distance / anode-cathode distance".
