September 16, 2026, 11:10:26 am
Hoffman Amps Forum image Author Topic: Master volume for Tweed deluxe  (Read 20047 times)
Offline Leevi
    • Rikstone
« on: September 25, 2011, 05:44:46 am »
This subject has probably been handled here earlier but I ask anyway.
Is there a working/proven solution for a 5E3 master volume?
/Leevi
Re: Master volume for Tweed deluxe
« Reply #1 on: September 25, 2011, 06:03:34 am »
Offline Leevi
    • Rikstone
« Reply #2 on: September 25, 2011, 07:47:15 am »
Thanks Kagliostro for your response.
I have drawn the following power amp based on 5E3 and would like to get
comments regarding the PPIMV in the picture. Do you think it would work as it has
been drawn?
/Leevi
« Reply #3 on: September 25, 2011, 07:52:22 am »
That'll work. I'd probably use 500K pots and replace the 2.2megs with 470Ks.
« Reply #4 on: September 25, 2011, 07:53:28 am »
Hi Leevi
Yes I think it will work
you can also try this
http://www.el34world.com/Forum/index.php?action=dlattach;topic=10243.0;attach=19862
Kagliostro
p.s.: I think that the two resistors, between the wiper of the pots and ground, in your cathode bias amp aren't necessary, if I'm not wrong their purpose is to avoid problems in fixed bias amps if the wiper disconnects
« Last Edit: September 25, 2011, 08:10:55 am by kagliostro »
Offline Leevi
    • Rikstone
« Reply #5 on: September 25, 2011, 08:50:08 am »
Yes I was wondering the same thing. I have originally got this setup from some forum related to XITS amp.
Maybe it scales the control somehow?
Sluckey, what is your idea in this?
/Leevi
« Reply #6 on: September 25, 2011, 09:02:35 am »
The 2.2meg are used to keep the grid biased (either negative bias voltage for fixed bias amps or ground return for cathode biased amps) in the event that the pot wiper fails open. It's a good idea. But 2.2meg 'may' be more grid resistance than a 6V6 would like to see.
My idea of using 500K pots and 470k resistors will still give the original grid resistor value of 220K (or close enough). Now if the pot fails, the grid resistance only goes up to 470K which is fine for the 6V6.
That's just the way I'd do it. Your values works fine too.
Offline Leevi
    • Rikstone
« Reply #7 on: September 25, 2011, 09:36:02 am »
Ok, thanks. I suppose linear pots would work better in this?
/Leevi
« Reply #8 on: September 25, 2011, 11:25:47 am »
I would use audio taper for the same reason to use audio taper for most all volume controls.
Offline FYL
« Reply #9 on: September 25, 2011, 01:24:41 pm »
My fave is the bootstrapped PI MV, KOC-style. Transparent at all settings, low parts count, just what the doctor ordered.
Offline Leevi
    • Rikstone
« Reply #10 on: September 25, 2011, 01:39:29 pm »
Looks quite simple FYL. Have you tried it? Are there any drawbacks?
/Leevi
Offline FYL
« Reply #11 on: September 25, 2011, 02:12:54 pm »
Very simple, very effective. It's my standard MV for concertina-based power amps. No drawbacks. Some have reported a form of signal leakage at very low settings diminishing it's effectiveness but it's IMO a wiring/routing problem in their builds.
You may also play with the 10K grid R. Using a 220K or 330K - Merlin B. advocates up to 1M - cuts nasty blocking disto when the amp is overdriven.
« Reply #12 on: September 25, 2011, 02:20:55 pm »
OK Sluckey thanks to explain the use of those resistors, I was wrong thinking they will be only for fixed bias
FYL the difference of your bootstrapped PI MV compared to a standard PI MV is that the pot reach the ground crossing the resistor instead of directly
can you or someone explain which is in detail the difference in function ?
Kagliostro
« Reply #13 on: September 25, 2011, 02:23:07 pm »
Hi guys, Got PPIMV on my last build and so far no problems.  :icon_biggrin:
Offline phsyconoodler
« Reply #14 on: September 26, 2011, 12:43:33 pm »
FYL,
Can you show your master version in a layout? I am having trouble seeing it as it is(just me and schematics)
Offline FYL
« Reply #15 on: September 26, 2011, 02:37:15 pm »
A typical PPIMV is a resistive attenuator in series, with bandwidth and tone depending on RC time constants. Some work very well, others are unusable.
A bootstrapped MV wraps a stage and creates a local positive feedback loop. RC time constants are fairly constant for all settings, even if the R portion is seen reflected at many times it's actual value.
In the Concertina the MV stands atop the bottom bias resistor, keeping bias current nearly constant for all settings.
« Reply #16 on: September 26, 2011, 07:30:39 pm »
Here you go. This is my 5E3 layout with that exact MV.
« Last Edit: September 26, 2011, 07:36:50 pm by sluckey »
« Reply #17 on: September 26, 2011, 08:18:36 pm »
hey steve, couple of questions... have you had any oscillation tendencies with the 1st stage grid-leaks (68Ks) on the ckt. board, and have you built the 5E3 with FYLs concertina MV, or did you just post the dwg. to help mr. phsyconoodler?
much thanks,
--DL
« Reply #18 on: September 26, 2011, 09:56:29 pm »
I've not had any oscillation problems with the 68Ks on board. I also have never really pushed this amp. Been in the bedroom since I built it. The layout is similar to the original. I don't have the MV on my amp. I just drew that for phsyco. Bet he likes the schematic better now!    :laugh:
« Reply #19 on: September 26, 2011, 11:00:01 pm »
thanks, good to know... on the breadboard, i can't tell if one method is better than another. with the high gain stuff i prototype, experience has shown that lead-dress is by far more critical.
 :icon_biggrin:
did you really use 1W CC for the plate loads? seems like overkill, unless you have a large stash of 100K and 56K 1W CC which no one still seem to want.
peace.
--DL
« Reply #20 on: September 27, 2011, 06:21:50 am »
I did. Somewhere along the line I heard they were less noisy than 1/2 watters. I don't know if that's true though. And I really used 2 watters on the power rail. I have access to a large stash of 1/8, 1/4, 1/2, 1, and 2 watt CCs. Most sizes have a complete value range from 1 ohm to 10meg, including numbers that you likely never saw in a local tv shop, ie, 11x, 16x, 20x, 24x, 30x, 36x, 43x, 51x, 75x, 91x. They've been in bench stock for over 30 years, so I have to check'em befor I use'em.
« Reply #21 on: September 27, 2011, 10:01:50 am »
they would be a bit less noisy. don't think you could tell though.
nice compliment of power tubes.
i tried the bootstrapped concertina MV on my breadboard last night. indeed, it is very transparent. i use a 680K-1M for the grid-leak. the 1M starts shaving off highs noticeably. 820K is fine. i did revert to the 1M grid-leak since the amp i am bread-boarding is bright.
peace,
--DL
Offline Leevi
    • Rikstone
« Reply #22 on: September 27, 2011, 11:26:34 am »
I'm currently building a 5E3 with MV and would like hear more technical pros/cons which one the
proposed MVs I should select: bootstrapped concertina MV or PPIMV?
/Leevi
« Reply #23 on: September 27, 2011, 11:50:32 am »
bootstrapped concertina gets my vote. but then again i build weird stuff, so take my advice accordingly...   :icon_biggrin:
peace.
--DL
« Reply #24 on: September 27, 2011, 01:11:37 pm »
Many thanks FYL
Sluckey your amp has a fantastic layout !  :worthy1:
Kagliostro
Offline skeezbo
« Reply #25 on: September 27, 2011, 07:04:43 pm »
Has anyone tried the crossline master volume on an amp with a cathodyne inverter? That one seems very simple, too, as far as the parts count, but no one has mentioned it.  No good?
Skeez
« Reply #26 on: September 27, 2011, 08:26:19 pm »
Yes, I have done the crossline master volume with an on/off 1M pot. It doesn't sound very good at all, IMO. I almost never turned it on.
Offline FYL
« Reply #27 on: September 28, 2011, 02:52:20 am »
The crossline shows a very limited useful range with a huge loss of transparency/brillance at low to mid settings. Not very useful IMO, except in some overly bright EL84-based amps.
Offline Fresh_Start
  • noob de Lux
« Reply #28 on: September 28, 2011, 09:14:30 am »
I had similar, poor results trying a crossline PPIMV in a Princeton Reverb.
Cheers,
Chip
Quote from: jjasilli
Quote from: PRR
« Reply #29 on: September 28, 2011, 09:34:34 am »
Poor results here also. My Matchless Lightning clone has a crossline MV and I find it almost useless in the bedroom. It may be more useful in a clube environment though. The lightning uses a LTP PI. I don't think the type PI is a factor for the crossline.
Offline harryk
« Reply #30 on: September 28, 2011, 10:06:24 am »
I have used normal master volume in front of PI and more and more different PPIMV variations in my Bluetone amps. I think that PPIMV is very useful when someone wants to get distortion also from PI, not only from power tubes.
« Reply #31 on: September 28, 2011, 11:59:45 am »
I have tried the bootstrapped master in a Princeton circuit and I hate it.I might try Leevi's version.
« Reply #32 on: September 28, 2011, 12:04:44 pm »
same here - i have accepted the fact that about 1/4 of maximum is about all the cross-line is good for with acceptable fidelity loss. IOW, don't expect it to turn a 15W amp into a 1W bedroom amp - it'll sound like doo-doo if you do...
peace.
--DL
« Last Edit: September 28, 2011, 12:06:47 pm by DummyLoad »
Offline harryk
« Reply #33 on: September 28, 2011, 01:07:20 pm »
I got very good results in my latest Bluetone Tweed Deluxe amp scaling the whole amp with VVR. I did not use any master volume and customer is very happy with that amp at the moment. I have done VVR to tens of amps and it seems that for some reason it works best with amps without negative feedback loop  :w2: .
Offline Leevi
    • Rikstone
« Reply #34 on: September 28, 2011, 01:59:31 pm »
Harry, IMO the amps sound better without NFB even there is not a VVR inside.
/Leevi
« Reply #35 on: September 28, 2011, 03:35:34 pm »
That is pretty subjective.I prefer negative feedback in amps like the princeton reverb and super reverbs.Removing it is a cool tone to be sure,but it is better overall for my style with it in place.I like both,so I use a switch for both modes.
Offline FYL
« Reply #36 on: September 28, 2011, 04:41:50 pm »
The Princeton uses a feedback loop which includes the concertina gain and PI sections plus the output stage and the OT. A bootstrapped MV - which modifies the gain of one of the stages in the NFB loop - isn't the best with these topologies, a nice type II PPIMV works much better.
Offline Leevi
    • Rikstone
« Reply #37 on: September 29, 2011, 12:03:37 am »
I have also used NFB switch in many amps which I find very beneficial.
I have repaired lot of vintage amps and have noticed that in many of the them
the NFB has been disconnected. The switch gives the user possibility to
return to the original sound.
/Leevi
« Last Edit: September 29, 2011, 03:56:18 am by Leevi »
