August 03, 2026, 06:09:51 pm
Hoffman Amps Forum image Author Topic: Face/Back plate of Marshall JCM glue-down...  (Read 8301 times)
Offline mrr3000gt
  • Idiot Savant Engineer
    • Sponsored by Dimarzio Pickups since 2010
« on: September 26, 2011, 02:10:37 pm »
I have a Marshall JCM 2000 DSL (please...I know...) that needs to have the rearplate glued down.
What is good to use when re-tacking down faceplates/rearplates on the marshalls (and please, no suggestions to use railroad spikes!).
What I have is a part of the rearplate is comming off - I just want to use some type of cement that is typical for a faceplate that can take heat & stress.
Thanks,
-mike
« Last Edit: September 26, 2011, 03:18:04 pm by mrr3000gt »
Re: Face/Back plate of Marshall JCM glue-down...
« Reply #1 on: September 26, 2011, 04:43:33 pm »
I have tried all kinds of glue and have found nothing that will over time keep the rear plate in place. Heat is probably the main factor. I used tiny bronze screws on a 1974 MKII. Pictured was my glue attempt. Sat 2 days and i thought i was done with it. I had used 3M spray adhesive. There may be a glue out there some one else can say has worked for them. I may try marine 5200 on my next repair. Marine 5200 is really great stuff. It needs about 2-3 days to cure good though if you have that much time /
« Last Edit: September 26, 2011, 04:47:45 pm by plexi50 »
Offline phsyconoodler
« Reply #2 on: September 26, 2011, 05:02:25 pm »
3M adhesive spray is useless IMHO. I've tried it for tweed and tolex and it wouldn't hold either for more than a couple of days without lifting.
 Good old contact cement,the smelly kind,works fine.Tolex is another story.
Offline mrr3000gt
« Reply #3 on: September 27, 2011, 12:34:03 pm »
I am not much of a glue-ologist: what is the brand of contact cement to use, and is it similar to what Marshall uses?
Also: Plexi I love the high-tech use of that laptop battery for a glueing straight-edge! That will be my next problem to solve - clamping.
« Reply #4 on: September 27, 2011, 01:37:16 pm »
I thought that was an old VCR camcorder battery!    :icon_biggrin:
« Reply #5 on: September 27, 2011, 07:17:49 pm »
 :laugh: Yeah i have a bunch of old Panasonic camcorder batterys that i found other uses for. Im a pac rat
« Reply #6 on: September 27, 2011, 07:32:30 pm »
They make nice pavers.  :icon_biggrin:
« Reply #7 on: September 28, 2011, 01:24:55 am »
Have you considered sponge adhesive tape ?
there are type with a very very thin sponge <adesivetape-sponge-adesivetape> that are very strong, also if exposed to U.V. ray
those tapes are used to attach mirrors in a quick and strong way
Kagliostro
« Last Edit: September 28, 2011, 01:40:15 am by kagliostro »
Offline The_Gaz
« Reply #8 on: September 28, 2011, 02:15:45 am »
what about silicone?
Offline timbraun
« Reply #9 on: October 12, 2017, 09:03:55 pm »
I tried some LePage's carpenter's glue. That didn't work, doesn't adhere to metal very well.
Marshalls, and Fenders, and Vox's! Oh, My!
Offline Tone Junkie
« Reply #10 on: October 12, 2017, 09:15:23 pm »
I use double sided sticky tape . They have all kinds, some of it is almost impossible to get apart . Most I have  found  get harder with age. I have some back plates going on 3 yrs. still stuck strong . that was with stuff made for carpets.
Bill
Offline bnwitt
  • Crankin' out the tone.
« Reply #11 on: October 13, 2017, 08:23:43 am »
forget the glue.  Use a screw or screws
« Reply #12 on: October 13, 2017, 12:17:17 pm »
JB weld. it'll never come off again.
« Reply #13 on: October 13, 2017, 05:10:50 pm »
...or something like this  https://www.amazon.com/Gorilla-Epoxy-85-oz-Clear/dp/B001Z3C3AG/ref=sr_1_1?ie=UTF8&qid=1507932527&sr=8-1&keywords=glue+for+plastic+and+metal
make sure both surfaces are clean and free of wax, dirt, oils,,,   etc.
Offline alerich
  • This one goes to 11.
« Reply #14 on: October 21, 2017, 08:15:25 pm »
This. That stuff is amazing.
Offline BlackCrowe604
« Reply #15 on: October 23, 2017, 01:34:53 am »
Try a thin layer of 2-part epoxy - should work fine!
Or, Loctite AA H8610 - I use this stuff at work to glue plastic to stainless, and have used it on metal-to-metal surfaces and it's pretty much indestructible. $$ though   http://na.henkel-adhesives.com/product-search-1554.htm?nodeid=8797944414209
