September 14, 2026, 03:19:49 am
Hoffman Amps Forum image Author Topic: Silvertone 1448 guitar case amp  (Read 10394 times)
Offline jim
« on: October 01, 2011, 03:39:08 pm »
A guy want me to "restore" this.  It lights up fine on the limiter but there is no sound at all.  I cannot get any click from the speaker by using a battery.  I'll try a 4 ohm speaker later.  Obviously I'll need to install a polarized AC plug with safety ground.  I have never worked with an isolation transformer and I know I'll need one.  What is appropriate and how do I wire it?  Can it fit inside the box or
perhaps externally on the box? BTW, the "chassis" is press board.....
Re: Silvertone 1448 guitar case amp
« Reply #1 on: October 01, 2011, 10:03:01 pm »
Offline jim
« Reply #2 on: October 02, 2011, 07:00:40 am »
Thanks, PRR.  The amp works fine with a known good speaker and actually has decent low volume tone.  I'll make it safe to play.
« Reply #3 on: October 02, 2011, 09:34:30 am »
Should he yank C3 (cap from filament string to chassis) after installing the iso transformer?
« Reply #4 on: October 02, 2011, 11:10:21 am »
I would. In fact, I'd replace it with a piece of wire.
Offline jim
« Reply #5 on: October 02, 2011, 06:06:15 pm »
got it! thanks.   Jim
« Reply #6 on: October 03, 2011, 12:00:54 am »
It needs "something" there to return V1 DC current and pass signal from V1 to V2.
What do we want?? To make it "good"? Or leave it sadly-stock (except no-shock)?
You could quickly make a very-good case-amp with a heater transfo and an LM386 or LM383 chip-amp. Get new pressboard, transfer the trim, all reversible for eventual collector value.
If you like tubes, Epi Jr, stock or mod, is a much "better" tube amp at bargain price.
IMHO, if you are gonna futz with this, it is for "original flavor". Not hot-rod potential.
R5||C3 limit shock-current but also affect operation of V1 so that it must strain more to drive the 50C5. "Fix" it, less flavor.
But WTH. You can instantly jumper R5||C3 and try both ways.
Offline CraigB
« Reply #7 on: July 17, 2019, 09:18:27 am »
Just want to make sure I am following the diagram PRR posted above correctly for wiring one of these up with the triad isolation transformer.  Does the green line represent U-ground on a three-prong power cord?  Also, apparently there is no advantage to having a separate 12.6v filament supply for the 12AU6?  Thanks!
« Reply #8 on: July 17, 2019, 11:12:26 am »
...Also, apparently there is no advantage to having a separate 12.6v filament supply for the 12AU6?
no - it is not needed.
yes. power source ground to chassis.
« Reply #9 on: July 17, 2019, 12:34:39 pm »
The original 12AU6-only heater transformer was a halfway measure to decrease shock around the input jack (12AU6).
Now that you have the WHOLE amp on a proper power transformer, that cheater transformer is redundant.
It is like putting a muzzle on a vicious dog, or putting the whole vicious dog inside a cage. With a proper cage you don't need the muzzle.
Obviously in context of a $9.98 amplifier the kid would out-grow in a year (if he lived), the halfway measure was preferred. Now 60 years later, if you are still messing with these things it is justified to make them safe-safe-safe, and incidentally clean-up halfway safety measures.
Offline CraigB
« Reply #10 on: July 17, 2019, 12:48:06 pm »
Many thanks Gentlemen!
