September 08, 2026, 12:05:14 pm
Hoffman Amps Forum image Author Topic: Finishing my pickup coil winder. Where to mount the wire guide?  (Read 5604 times)
Offline stingray_65
« on: October 16, 2011, 10:56:14 am »
I finished up the pickup coil winder last night,
I was going to mount the wire guide, but I have no idea how far away to mount it.
The guide is adjustable vertically, and I know it has to run lower than my center-line of the shaft.
I just don't want to drill a line of tapped holes and guess. Broken wire and experience can get expensive.
Any suggestions or preferences any of you might have would be great.
Ray
« Last Edit: October 17, 2011, 12:22:57 am by stingray_65 »
Offline shortfuse
Re: Finishing my pickup coil winder. Where to mount the wire guide?
« Reply #1 on: October 26, 2011, 10:51:18 pm »
Wish I could help you Ray but have no idea these are uncharted waters for me, but it sure looks fantastic.  Is that a winding counter to the side of it or a digital rpm gauge.
Offline stingray_65
« Reply #2 on: October 26, 2011, 11:39:08 pm »
It's an old Omron counter I salvaged from a press at work when we sent it to scrap.
It only will count  up to 20Hz so I can only count up to 1200 RPMs.
Thing is the motor is capable of 3200 RPMs and a 2:1 cog ratio puts me at 1600 RPMs.
So I choked the speed down a bit with a fixed resistor on the  speed control signal.
In retrospect I should have mechanicaly limited its speed with the right cog ratio of 2.5:1
