September 17, 2026, 06:17:48 am
Hoffman Amps Forum image Author Topic: Volume Pot Testing  (Read 5089 times)
Offline blown240
Volume Pot Testing
« on: October 18, 2011, 10:26:05 pm »
Is it weird that the resistance in my volume pot is highest when the shaft is centered?   If I put my meter on the center and either side, the readout goes from 0-250-0 as I sweep thru the range of the pot. Seems like it should go from zero to its highest point.
Will this cause problems?
Offline Danskman
Re: Volume Pot Testing
« Reply #1 on: October 18, 2011, 10:48:20 pm »
Did you measure it apart from the circuit? If not, could be due to the circuit itself; please post schematic. A pot should not react by itself like the one you describe.
BR,
Danskman
Offline stingray_65
« Reply #2 on: October 18, 2011, 10:49:32 pm »
Where did you get the pot?
What is its stated value?
Sounds like some sort of balance pot.
Get a new one.
Offline blown240
« Reply #3 on: October 18, 2011, 11:20:04 pm »
Ya I tested it by itself, and got a new one.
« Reply #4 on: October 19, 2011, 06:48:50 am »
Are you using that Fluke T5-600 Electrical Tester? Specs say it only measures up to 1000 ohms. It's a continuity tester, not a proper ohm meter.
Offline blown240
« Reply #5 on: October 19, 2011, 11:01:26 am »
no I bought a DVM that I am using.  Its a cheap one, but seems pretty accurate.
stratele52
  • Guest
« Reply #6 on: October 19, 2011, 03:51:43 pm »
Don't forget volume pots are most of the time "audio" type, or logarytmic. Resistance are not equaly each side.
Other  ( almost all)  pots are "B" linear
Here , you'll see how to mesure "audio "pot. if not sure . Look a the bottom of pages
http://www.ladyada.net/library/metertut/resistance.html
