August 29, 2026, 09:40:28 am
Hoffman Amps Forum image Author Topic: Doug's custom board progam rocks  (Read 4492 times)
Offline ernie_jr
  • gimme a banana
« on: October 24, 2011, 09:18:16 pm »
Doug,
Again your order came thru perfect. Ordered Friday evening, in mailbox Monday afternoon. The custom turret board
built with your new program is perfect.
Great program for us, and great service.
Ernie
Re: Doug's custom board progam rocks
« Reply #1 on: October 30, 2011, 05:09:02 pm »
Cool.
It worked out great on this end also.
I was wondering about that lone lug hanging out on the right end of the board, but I figured you had double checked your work.
Hope everything was in the right place for your build.
I still have to add some more things to the program and it will be finished, but it works if anyone else wants a custom turret board cut.
If you really want the board cut, then you have to email me with your file number and I will add it to your order.
(First, create an order on the shopping cart)
See this post
http://www.el34world.com/Forum/index.php?topic=12317.0
« Last Edit: October 30, 2011, 05:11:45 pm by EL34 »
Offline ernie_jr
  • gimme a banana
« Reply #2 on: October 30, 2011, 06:08:07 pm »
Doug,
The lone lug was as easy way to get the board a longer length in case I needed some more room.
Ill keep the board posted on the ampeg home brew I am making with the board.
Ernie
« Reply #3 on: November 01, 2011, 07:21:57 am »
ah, ok, that splains the lug
I was thinking it was a common ground lug or power cord lug point
thanks for the update
