September 17, 2026, 07:15:39 pm
Hoffman Amps Forum image Author Topic: Question regarding low plate voltage and high current (with measurements)  (Read 7692 times)
Offline bruno
  • got to love that glow
I've grown curious about output sections working with low plate voltage and high current. I have an alessandro bluetick amp that was shipped with 4xEL34s but also works with other octal output tubes (6V6s, 6L6s, etc.)
I've also taken notice of a new amp being release by 65 amps (called the producer), where they claim to run their tubes in a very "unconventional way" which allegadly extends the lifetime of the tubes 20 some years, and allows them to run cool and healthy. They also claim, their's to be the only amp in the market that does so.
Well I know for a fact that the alessandro runs in class A and I've taken some voltage readings in the inside of the amp. The plates on those EL34s measure 228Volts. The voltage at cathode pin before the cathode resistor/cap is 12V. The cathode resistor value is 82ohms with a 100uf cap across it and each two pairs of el34s have this combo on their shared cathodes.
I also know for a fact that my alessandro runs HOT, really HOT.
My questions are the following:
-How is it possible that 65 amps claim their tubes to run really cool, by using low voltage and high current? Are they doing something else which I'm missing, because the alessandro also has low voltage and I figure must have some high current to work in class A and yet the tube are running really hot.
-How should I go about measuring the current on the el34s of the alessandro? I know the plate voltage and cathode voltage, I know it runs in class A so the dissipation ought to be 100%, right?
thanks
EDIT: by the way here is a photo of the inside of the alessandro it's very similar to a fender blackface in some aspects, with some slight value changes in the tonestack, the fact that the output tubes are connected in ultralinear fashion and the preamp/PI tubes are octal (obviously it has it's own voice going on, which is why I like it). Also the filtering is 47uf across all sections.
« Last Edit: October 25, 2011, 06:53:56 pm by bruno »
I watched a little of the 65 Producer ad too. My thought was that they do lower the voltage, but then set the bias to still get the 70% or whatever. Probably more to it than that.
As far as how long the tubes actually last, we'll see in 10 years or so. Heck, the tubes in my Harmony were original and still sound fine. I guess 20 years of storage helped.
I think the whole thing is mostly a new way to market "class A" but not say it cause everyone's marketing team has made class A 20-years-ago's buzz word.
"The voltage at cathode pin before the cathode resistor/cap is 12V. The cathode resistor value is 82ohms"
12V across 82 ohms is 0.143 Amps or 143mA.
This appears to be per-pair? Then roughly 71mA per tube.
How do you know that?
To get the most out of your tube-dollar, yes.
Tube-dollar may not be the most important thing. You sure can run tubes far below their ratings.
Minus 12V at cathode, 216V plate-cathode.
Times 71mA per cathode, 15 watts per tube. Assuming G2 current 15% of plate current, then 13 Watts per plate. Half of original rating on EL34.
Chassis is mighty small for 4*0.071mA*228V= 65 Watts of total heat.
I don't think I recall 65 amps claiming their tubes run cool. I do recall them saying your tubes would last 20 years. I'd like to know how they arrived at that number.
The cathode of a tube won't last forever, and there's many things that can cause a tube to have reached the end of its useful life that have little to do with how its used. However, abuse typically hastens end-of-life.
I got the impression that they designed the amp to be within modern production tubes' ratings, and not necessarily designed for maximum power output (like when he said 2x EL34 amps were too loud). I wouldn't sweat the details of a brief demo aimed at selling you a 65 amp.
Besides, the only potential selling point was being able to switch between different distortion sounds and clean sounds at a single volume level. It sorta did that, but the distortion sounds weren't "wow" to me. And I didn't feel the clean sound (based on what was captured by probably the interviewer's mic) was any better than what you could get out of an early-70's Marshall.
You could install a VVR in an amp in a fixed position setting a low voltage on the power tubes.
with respect, Tubenit
Offline bruno
that would make some sense, as far as marketing goes, the "class A" term went from being the greatest thing ever, to some people realizing that class of operation doesn't really matter as long as you like how the amp reacts and sounds.
That looks like the calculations I made were correct.
As far as the chassis being too small, I though so too, but then I tried running the amp with the chassis out of the cab so it had plenty of ventilation, and it was still quite hot, obviously the fact that the quartet of EL34s is really close together physically might not help.
I assume I know it's operating class to be A, because George claims his amps are designed to work in class A at full unclipped output of the amplifier. I'm no good with looking at load lines to check if this is true or not, but the transformers are specially made by magnequest for an amp that runs at really low plate voltage and high current.
It must also be noted that his amps use ultralinear taps, going to the grids of the tubes with 1k resistors for a total of 233v at the grids.
What do you think, could it be considered to be operating in class A? George rates this amp at 20 Watts. It sure doesn't feel like a 60 watts amp, more like a 15-25 watts one.
I saw a webcast by Dan Boul, where he claimed no one else in the market to be using tubes this way (which I think is not really accurate), where he also claimed typical EL34 amps don't sound that good clean (which I also think is incorrect) and finally where he said their new producer amp, ran so cool you could pickup the tubes by hand after hours of play and while they might still be warm, you wouldn't even get burnt.
I've taken that into consideration too, might be a nice option.
I'd also like to add that, despite the fact that part of the topology of the alessandro is pure fender, the amp sounds and responds very differently from a 60s fender, it sounds really really great with it's own voice going on and never harsh with great top end extension, plenty of chime and lots of definition. Despite all the filtering it doesn't respond in a stiff way and it's very linear, everything responds very smoothly, more so than any other amp I've tried. The transition from clean sounds to distorted ones, is non existant, it just blends into saturation in a marvelous way.
« Last Edit: October 26, 2011, 11:11:13 am by bruno »
