September 17, 2026, 02:05:34 pm
Hoffman Amps Forum image Author Topic: 12AT7 PI in place of AX...should i change component values?  (Read 6934 times)
Offline 12AX7
« on: November 05, 2011, 03:32:22 pm »
Same amp i was asking about before, and i found a T7 in place of the X7 i had in the PI makes a big improvement. However, should i change component values at the PI? Right now it has 2204 values and about 300V at the plates.
Re: 12AT7 PI in place of AX...should i change component values?
« Reply #1 on: November 05, 2011, 03:35:30 pm »
If you like it, let it be. Nothing will be harmed.
stratele52
  • Guest
« Reply #2 on: November 05, 2011, 03:44:00 pm »
You don't need to
Offline 12AX7
« Reply #3 on: November 05, 2011, 04:22:28 pm »
I just wanted to be sure it's optimal since it's not the perfect solution. If it were i wouldn't even ask, but it's close. So if it won't help to tweak i'll leave it alone. I was just under the impression they were suppose to be biased differently than an AX7.
« Reply #4 on: November 06, 2011, 10:21:12 pm »
Not necessary to change any components in the PI for a 12AT7, especially if its a LTP
