September 19, 2026, 12:33:02 am
Hoffman Amps Forum image Author Topic: Choke orientation  (Read 5400 times)
Offline firemedic
Choke orientation
« on: November 13, 2011, 05:46:27 pm »
Is it important to orient the choke laminates perpendicular to the OT laminates?
I have a TR chassis I'm trying to put a 100w Marshall style OT on, and it fits much better parallel, and right next to, to the choke. Will this position cause too much noise/hum?
Re: Choke orientation
« Reply #1 on: November 13, 2011, 06:00:07 pm »
To me seems that is important the orientation of the OT with respect to the PT
so if you put the choke perpendicular to the PT and the OT perpendicular to the PT
the OT will be in parallel with the choke
so I think is better to have choke & PT parallel and OT perpendicular to both PT & choke
Kagliostro
Offline firemedic
« Reply #2 on: November 13, 2011, 06:09:11 pm »
Due to the flat  "in-chassis" PT mounting in a Blackface chassis, all 3 can be perpendicular to each other.
« Reply #3 on: November 13, 2011, 06:29:53 pm »
We can know from Fender practice that the stock Twin Reverb orientation doesn't have a noticeable hum problem.
In Building Valve Amplifiers, Morgan Jones points out that although chokes have an air gap, and therefore have significant flux leakage, the amount of a.c. across the choke is small compared to a PT or OT. For that reason, the choke won't leak a large amount of flux to induce hum in the OT.
The exception is a choke-input power supply, which has a large a.c. component across the choke. Most guitar amp power supplies are cap-input, however.
Offline firemedic
« Reply #4 on: November 14, 2011, 12:18:54 pm »
Thanks!
