September 19, 2026, 06:08:34 am
Hoffman Amps Forum image Author Topic: PPIMV with using 2 different pots of the same value  (Read 6144 times)
« on: November 15, 2011, 08:39:43 am »
Anyone ever done a Master Volume without using a dual pot?  I am asking for 2 reasons, 1 is I don't have a Dual pot on hand and the other is what type of effect you may be able to get from having them separated.  I don't know if it would cause any problems either.
Re: PPIMV with using 2 different pots of the same value
« Reply #1 on: November 15, 2011, 09:01:01 am »
See if you can find a schematic of Kevin O'Connor's TUT series "Soma18".  It has a feature that would somewhat answer your question.
Short answer is yes I think that can be done and create a psuedo "SE" however my understanding is that it is not that great of a tone.
IF you always turned both pots exactly the same there would be no issue.
Offline phsyconoodler
« Reply #3 on: November 15, 2011, 02:16:43 pm »
Just use a single 1 meg audio pot as per the Trainwreck pages.It works fine,maybe not quite as good as the others but pretty damn good IMHO.
« Reply #4 on: November 15, 2011, 02:58:19 pm »
Are you just tying into the junction of the cap and resistor and not lifting anything?
« Reply #5 on: November 15, 2011, 03:16:43 pm »
Yes. I have that simple crossline MV on my Matchless Lightning clone. I hate it! But I'm a bedroom picker. Might be more useful in a club scene.
« Reply #6 on: November 15, 2011, 03:40:15 pm »
This amp I am looking at adding a master is my baby.  It is sort of a 5f4, fixed.  Tried a VVR in it and pulled it.  I would like to tame it a little for round the house, but it is my favorite amp so I don't want to mess it up.  Right now I can use the tone controls to get a nice sound, but it is still kinda of loud for the house.  That is why I was interested in the SE arrangement, but if the tone is not that great, I might as well leave well enough alone.
Offline chocopower
« Reply #7 on: November 15, 2011, 05:23:42 pm »
Done and tested im my cathode biased amp.
Instead a pot, i put a switch, so i can go from top to down of the "pot" in a flip...
IMHO, sound way better than others attenuation methods i had tryed. (crossline MV, cathode caps switch, external attenuator)
Just waiting next time i open my Proreverb clon (fixed bias, of course) to test it.
more information.
http://www.el34world.com/Forum/index.php?topic=12251.0
so..
for cathode biased amps: TESTED. (ignore the grounded 6V6 cathodes without resistor... mistake)
and for fixed bias amps: NO TESTED.
if you want a pot ( i tried and just used the extreme options..), just change the switch for the pot and quit the 220k resistor in that side of the PI.
« Last Edit: November 15, 2011, 05:32:28 pm by chocopower »
David
