September 19, 2026, 05:05:38 pm
Hoffman Amps Forum image Author Topic: FAT SWITCH schem needed, please.  (Read 6472 times)
Offline Colas LeGrippa
  • MAKE LOVE NOT WAR
« on: November 18, 2011, 04:10:36 pm »
Hi, I need to hook up a fat switch to a JCM800 .  A device that doesn't pop when switched, and that doesn't hum either. Any drawing / schem ?
Regards
Colas
P.S.: call me Alvin.
Offline chocopower
Re: FAT SWITCH schem needed, please.
« Reply #1 on: November 18, 2011, 06:50:13 pm »
You can put a cap (1uf - 4,7uf - 22uf) bypassing the 820r resistor in the V2A cathode. I have done it several times without problem.
In one of my amps, i activate it via a footswicht (no relay, just close ground connection). You can put a 1M resistor as "anti-pop", but it dont use to be necesary.
Works like a champ
David
  • MAKE LOVE NOT WAR
« Reply #2 on: November 18, 2011, 06:56:55 pm »
cool, thanks I'll get back to you when it's done.
Colas
Offline Tone Junkie
« Reply #3 on: November 19, 2011, 02:53:25 am »
You can also put a cap across your 470p and 470k resister put a .0022 on one end and 1 meg resister on the other and join them in the middle then put the switch on both ends of the 1 meg which shorts the 1meg resister out of the equation when you flip the switch.
Causing the .0022 to boost the low and upper mids. without any noise. I used it for a solo boost in one of my amps sounds great in a jcm 800.
Thanks Bill
You will have to forgive my odd explination its late and Im tired.  :think1:
Offline rock_mumbles
« Reply #4 on: November 19, 2011, 04:07:13 am »
Another fat boost is to switch in an 82k resistor in parallel with the 470k resistor in the signal path.
« Reply #5 on: November 19, 2011, 06:53:58 am »
Just some different examples.  There are other ways also.  Some of these aren't applicable for the JCM800 but I thought I'd illustrate them anyway
I have used the Dumblish style mid boost and preamp boost on tone stack after a cathode follower and like them. No noise switching
with respect, Tubenit
« Last Edit: November 19, 2011, 07:40:20 am by tubenit »
  • MAKE LOVE NOT WAR
« Reply #6 on: November 19, 2011, 11:39:45 am »
cool diagrams, thanx, brotha'
Colas
