August 05, 2026, 04:11:37 pm
Hoffman Amps Forum image Author Topic: adding a gain stage to a JCM 800  (Read 13889 times)
Offline Colas LeGrippa
  • MAKE LOVE NOT WAR
« on: November 20, 2011, 08:45:17 pm »
Hi, I have built a new SE amp with the filtering and preamp section of a JCM 2204 that sounds amazing ( soon on youtube , I'll post a new topic when it's there ). I would like to add a switchable gain stage for
heavy rock / metal purpose. I have checked in the previous posts here, there and everywhere without finding something appropriate. Would you ( boys and girls) have something simple, easy and efficient to propose ? I can easily add one more 12AX7 to the chassis as the amp was originally designed for a push/pull amp and the PT is strong enough to supply heaters.
Best regards !
Colas.
P.S.: call me Alvin.
Re: adding a gain stage to a JCM 800
« Reply #1 on: November 20, 2011, 10:22:51 pm »
Here are a couple ideas. Be careful. HIGH GAIN!!!
« Reply #2 on: November 21, 2011, 05:54:16 am »
This would be switchable.  I have not built it, but I thought I'd offer it as a design to consider.
You would have a boost on paralleled V1 with switchable cathode caps
You would have a boost with the pre amp boost (PAB) on the tone stack
You would have a boost with the switchable Dumblish type OD section
I attached an editable SCH version also.
« Reply #3 on: November 21, 2011, 06:20:25 am »
IF you want a somewhat more relaxed not as intense OD, then this one would be worth considering.  I used this OD topology on a friend's amp that he loves.
This sound clip has this type of OD to it. It's articulate but not over the top.
http://www.soundclick.com/player/single_player.cfm?songid=10391428&q=hi&newref=1
  • MAKE LOVE NOT WAR
« Reply #4 on: November 21, 2011, 07:01:51 am »
my lord ! this gives me many hours of pure pleasure!
thanks a million.
Colas
Offline Boots Deville
« Reply #5 on: November 21, 2011, 07:45:02 am »
This link: http://i.imgur.com/40nC3.jpg
is to a layout I have squirreled away in the same folder that I have the AFD_Preamp image Sluckey posted, but I don't remember if I got them from the same place.   I haven't done anything with it, so I can't vouch for it's accuracy.  I also don't know if it matches that schematic, but if you decided to go the AFD route, maybe this layout info will help.
Cheers!
John
Offline bakerlite
  • Don't forget to play it...
« Reply #6 on: November 22, 2011, 03:14:08 pm »
That looks interesting,
Is there a shematic knocking around for that fella?
Cheers!
John
Cheers,
Bakerlite
Offline JayB
« Reply #7 on: November 22, 2011, 06:02:32 pm »
That's a really cool sounding amp. Reminds me of some real old Black Sabbath tones, sort of the same character.
You're going to hell faster than Britney Spears running to a Barber shop
