September 15, 2026, 07:54:51 am
Hoffman Amps Forum image Author Topic: Is this right ??!!  (Read 6905 times)
Offline worth
Is this right ??!!
« on: November 27, 2011, 01:15:44 pm »
Trying to track down a power supply hum , when I noticed these 2K cement resistors. They appear to have "grown together". Is this a specialized resistor of some sort ? I haven't seen one like this before.
Re: Is this right ??!!
« Reply #1 on: November 27, 2011, 01:29:39 pm »
I'm prone to think so
you can also observe it and look to the printed data
if only one is labeled is easy that is a "double" resistor
what about the other side of the moon (resistor) ?
are there 2 connection, 1 connection, or none ?
Kagliostro
« Last Edit: November 27, 2011, 01:32:15 pm by kagliostro »
Offline worth
« Reply #2 on: November 27, 2011, 01:37:17 pm »
Each resistor  says " Mexico 2K 10%" and both have 2 axial leads , like an ordinary cement power resistor.
Offline bigsbybender
  • Hack Of All Trades
    • Tube Amp Gallery
« Reply #3 on: November 27, 2011, 02:00:51 pm »
They are just two resistors that have grown together. That filler stuff must have gotten soft by either heat or atmospheric conditions.
j.
Open Minded But Fixed Bias
Offline worth
« Reply #4 on: November 27, 2011, 02:02:15 pm »
Yes.. but is it a problem ?
Offline bluesbear
« Reply #5 on: November 27, 2011, 03:42:24 pm »
Those things are cheap! I'd spend the few cents just to be sure.
Dave
« Reply #6 on: November 27, 2011, 04:08:56 pm »
It was somewhat common in early transistordom to have two small-signal transistors clipped together on one heat sink so that they would remain at the same temperature level.
I have never seen it with resistors.
    • Tube Amp Gallery
« Reply #7 on: November 27, 2011, 06:53:06 pm »
Do they read correctly on the meter?  If they are on the verge of burning up, then the values tend to drift.
It's not likely for these two resistors to have become conductive to one another, as that material is probably rated for 600v+.
j.
Offline worth
« Reply #8 on: November 27, 2011, 08:25:30 pm »
One resistor reads correctly EVENTUALLY. On one,  the meter reading starts low , then climbs slowly up to around 2K.. not like the usual resistor. On the other , the reading is way off.
« Reply #9 on: November 27, 2011, 08:42:12 pm »
You need to lift one of their end(s) and measure out of circuit.
« Reply #10 on: November 27, 2011, 08:44:42 pm »
you need to lift one end of each out of circuit to read them accurately - it seems as though one has a cap tied to one end and the other has other stuff in parallel. "it" looks to be 2 parts.
--DL
