September 14, 2026, 02:30:11 pm
Hoffman Amps Forum image Author Topic: 6G6B Bassman cutting outwith treble on 10  (Read 4810 times)
Offline Underwood
« on: December 05, 2011, 05:32:11 pm »
  Anyone here of this? Everything works and sounds great otherwise,but I just turned the treble up to ten while the Volume was on 7 or 8 and it lost volume and started cutting out. Turned the treble down and it was fine. I did remove a .02 cap right before the phase inverter on the schematic that was recommended for better tone for guitar.  MAybe that has something to do with it?
Offline phsyconoodler
Re: 6G6B Bassman cutting outwith treble on 10
« Reply #1 on: December 05, 2011, 05:40:48 pm »
What .02 cap are you talking about?the one across the plate resistor of V2? Hey Tubenit,pay attention to this one!
that would not do what you are describing I should think,but a bad treble pot will.An oscillation will cause this at certain frequencies too.do you have grid stopper resistors on the power tubes?
« Reply #2 on: December 05, 2011, 05:59:39 pm »
What he said. Clean or replace the treble pot. I don't see any .02µF cap in that amp.
