September 17, 2026, 01:48:28 am
Hoffman Amps Forum image Author Topic: Replacement power transformer for Sunn 300t (98 Fender model)  (Read 8327 times)
Offline six el six
« on: December 14, 2011, 04:54:22 am »
Anyone have any recommendation as to how I would go about sourcing a power transformer for this amp?
I'm guessing the B+ tap would need to be 530v?
19.4 v on the bias winding?
233v on the gray winding?
And a heater tap.
What I don't have a clue about is how to calculate the unloaded secondary voltages so I'm guessing looking for the secondary voltages I came to above aren't going to be what I'm really going to need.
Re: Replacement power transformer for Sunn 300t (98 Fender model)
« Reply #1 on: December 14, 2011, 02:26:25 pm »
> secondary voltages
And _currents_?
There are VERY few 300W amps, and very few PTs suitable for such beasts.
Fender is the obvious source. Mercury Mag and others may have a repro/upgrade.
Anything with six 6550 is of course "same as" an early Ampeg SVT. I'm sure SVT PT could be made to work, although the C- and opamp voltages may need additional small irons.
How dead is it? If the primary is wide-open, look for the thermal cut-out.
« Last Edit: December 14, 2011, 02:28:51 pm by PRR »
Offline six el six
« Reply #2 on: December 15, 2011, 02:55:36 am »
I pulled out what I believe to be the thermal cut out/fuse.
I've never seen one before.
It has no continuity that I can discern.
Pics attached.
I've contacted Merc Mag and Patrick wants voltage specs "preferably unloaded". How do I go about this with a high degree of precision?
I've never contacted Fender for replacement parts before but I guess I'm about to. Does anyone know the best way to get an exact replacement part from Fender?
Thank you.
« Last Edit: December 15, 2011, 03:38:16 am by SIX el SIX »
« Reply #3 on: December 15, 2011, 06:19:23 am »
Put a jumper across the terminals where that thermal cutout switch was connected. Does the PT work now?
You can get those at a small appliance parts house. They are used in coffee makers, hairdryers, etc. I'm not sure about ratings, probably a temp rating.
Offline six el six
« Reply #4 on: December 15, 2011, 04:16:56 pm »
This is a repair I'm doing for someone else.
Wouldn't it be illegal to NOT replace the transformer?
For that matter, digging the thermal cutout out of the tranny left me with three clipped wires and I don't clearly understand how it was wired.
Looking at the schematic, you'd think it would be simple, but...
I'm attaching an annotated pic.
What I don't "get" is does the silver wire on the left of the picture simply attach to one end of the thermal cutout?
The temp rating on the thermal cutout is 141 degrees celsius = 285 farenheit??!! Holy smokes!
« Reply #5 on: December 15, 2011, 06:15:01 pm »
Does the transformer smell burnt?
I see darkness on the outer layer but can't tell if that's toasting or just a different paper.
Offline six el six
« Reply #6 on: December 15, 2011, 09:19:15 pm »
No it does not.
The attached photo might be more helpful.
« Last Edit: December 15, 2011, 09:21:17 pm by SIX el SIX »
« Reply #7 on: December 15, 2011, 11:24:41 pm »
I'm puzzled how you removed a 2-wire part and came up with three loose ends.
The schematic shows the thermal breaker between the black lead and the 120V winding.
I can't identify the black lead in your image; you can see it better.
A wild guess is that the black lead may come under the winding in the TB pocket; and the two thinner loose ends are a winding which broke in the tear-apart.
Inventory your leads. Check continuity against the schematic.
If indeed the 120V is broke and you can't figure how it was, you may have a hard time getting voltage numbers for MM.
Hmmmmm.... the 6.3V winding should be obvious because leads are green and winding is FAT, and the ohms should be much less than 1. Get another PT with a 6V winding, plus a 10 ohm 10 watt (Radio Shack) safety resistor. Try to drive the sick PT's 6V winding with 6VAC through the resistor. Check voltage on each winding. The source should of course be 6V-7V. The "sick PT" winding would ideally be the same, but really somewhat lower with the resistor. If it is a little low like 5V, take the resistor out and drive directly. If a lot lower, under 1V, the sick PT has an internal short (and the open 120 is a secondary problem).
Anyway: with something like 6V on the green leads, measure all the other windings. BEWARE!! The 120V and 400V will be lethal, use clips, don't trust fingers.
With power OFF, measure winding resistances (you can't measure the 6V heater winding any reasonable way).
Patrick will also need the 6VAC current demand to back-guess its resistance. Six 6550 is 9A-10, and two littles is another 0.6A.
And he needs the nominal wall voltage ("120", "230", etc).
Core dimensions (outside height width stack) are important. Also note which ones are mechanically critical (mounting holes, any limit on overall height) or if he can adapt to existing stampings and you'll find a way to mount it.
If you have micrometer, wire gauges would save Patrick a few moments.
Once Patrick picks a core stack, he can pencil the turns for 120V and a gauge that fills 40%-45% of the window. Then the 6.3V winding is nominally 1/19th of that turn-count, except there will be about 5% sag so it has to be like 1/18 or 6.6V unloaded to get 6.3V loaded. Similar calcs for the other windings. He'll want the schematic to estimate ~~66VA in the heater but ~~600VA in the plate winding, and allocate window-space in proportion to power. Back-calc gives the current. Turns and area and insulation gives wire gauge. There is a nominal current density. All these calcs will give answers which are never a whole gauge number or a convenient number of turns (you like full layers) so there is a lot of tedious round-up/down and re-calc to come to a producible design. And he might discover that his conservative factors won't fit Fender's core... that Fender designed it down to the razor's-edge of excess warranty costs, and it might be wise to go next-up on core-size for more decades of use.
