September 18, 2026, 10:13:15 am
Hoffman Amps Forum image Author Topic: building a bias circuit from tranformer using full wave bridge and no center tap  (Read 8103 times)
Offline Tone Junkie
Ive tried using the standard method just going off one side and building a marshall type bias circuit but it hasnt worked for me. any insite on how to do it properly.
Thanks Bill
Please give other infos
Is this the schematic you followed ?
Kagliostro
Offline Tone Junkie
No but that one looks like its worth a try.
Thanks Bill
Look to Sluckey's Amp Scrapbook (the origin of that schematic)
there is also one other way to skin the cat
the Typical Marshall way (right & top of page 5)
http://home.comcast.net/~seluckey/amps/misc/Amp_Scrapbook.pdf
Kagliostro
p.s.: Thanks to Sluckey sharing that file
stratele52
  • Guest
Thanks Bill
Thanks Bill
Which Marshall you make and does'nt work ?
Offline Tone Junkie
Stratele52 I had a transformer that I had to use a full wave bridge because it didnt have HV center tap and when I did the standard marshall take off from one side like they use on the plexi amp it didnt work. I didnt have a marshall I just use that scheme alot.
I was actually making a trainwreck with spare parts I had laying around, i thought what the heck I can get what I needed from that transformer I just didnt do my home work first.
I will implemant one of the 2 ways shown in the morning.
Thanks Bill
« Last Edit: December 20, 2011, 01:46:58 am by Tone Junkie »
You have to include the series capacitor if you're going to come off one side of a bridge rectifier. This is done in Bogen amps. You see it a lot more when the main rectifier is a half-wave diode voltage doubler.
Offline Tone Junkie
Thanks guys I like comming here and asking questions I always learn something good here.
Bill
Offline Tone Junkie
Worked perfect guys thanks.
Bill
Glad you solved the problem  :smiley:
Kagliostro
