September 19, 2026, 10:12:23 pm
Hoffman Amps Forum image Author Topic: OT Suggestion For 36W EF86 Amp  (Read 5409 times)
Offline shortfuse
« on: December 20, 2011, 09:56:25 pm »
What OT would you guys suggest for a 4) EL84 Power Section, 36W EF86 build?
Re: OT Suggestion For 36W EF86 Amp
« Reply #1 on: December 21, 2011, 03:34:21 am »
Hammond 1760J
4.000ohm / 4-8-16ohm   35W
http://www.hammondmfg.com/pdf/EDB1760J.pdf
Kagliostro
Offline phsyconoodler
« Reply #2 on: December 21, 2011, 11:45:48 am »
That one will work as well as the AC30 replacement from Hammond.Depending where you are,getting an OT from Hoffman may be a good idea.He has the 35 watt Fender style OT's that have the right loading for a 4-EL84 amp.
« Reply #3 on: December 21, 2011, 12:17:37 pm »
See Doug transformer page
http://www.hoffmanamps.com/MyStore/catalog/parts1.htm
look to the 022848 that is the same destination transformer, only it has 4ohm output instead of multitap
$45.00 is a good price  :wink:
Kagliostro
« Reply #4 on: December 21, 2011, 02:15:30 pm »
doug's multi-tap 40W.
www.hoffmanamps.com/MyStore/perlshop.cgi?ACTION=enter&template&thispage=Transformers&ORDER_ID=!ORDERID!
Part number 018343
--DL
EDIT... Fixed link... sluckey
« Last Edit: December 21, 2011, 11:58:23 pm by sluckey »
Offline shortfuse
« Reply #5 on: December 21, 2011, 10:46:42 pm »
Thanks for the replies and suggestions.  I definitely want a multi tap but I am still contemplating between a 36 and 18 watt build.  If I go the 18 route I will definitely use Dougs Heybors.  I usually buy all my parts from Doug.
