September 19, 2026, 06:09:43 pm
Hoffman Amps Forum image Author Topic: vibrato circuit wanted !  (Read 4728 times)
Offline Colas LeGrippa
  • MAKE LOVE NOT WAR
« on: December 27, 2011, 05:15:43 pm »
Hi,
Got an extra 12ax7 on a chassis and I'd like to use it for a vibrato. It is a SE amp. 1 preamp tube, CF and one power tube. Never built a vibrato circuit before.
Any simple schem I could copy from a classic amp ?
Thankss
Colas
P.S.: call me Alvin.
stratele52
  • Guest
Re: vibrato circuit wanted !
« Reply #1 on: December 27, 2011, 05:31:03 pm »
Look on a Fender scheamtic, small amp
« Reply #2 on: December 27, 2011, 05:47:33 pm »
Fender VibroChamp.
If either of your gain stages don't have a cathode bypass cap (or if it's less than 10uF), that helps. If your amp doesn't have a feedback loop, just pretend that the 47 ohm resistor on the schematic isn't there.
  • MAKE LOVE NOT WAR
« Reply #3 on: December 27, 2011, 06:00:04 pm »
cool, thanks , I'll get back to you with final result ( if it works :icon_biggrin: )
« Reply #4 on: January 03, 2012, 01:23:35 pm »
FWIW this time last year I did this SE amp (see schematic) with a trem circuit using 1/2 a 12AX7 for the LFO and a IRF 820 source follower to drive the (parallel) output tube grid(s).
As it has cathode-biased output, the depth control doesn't really kick in until the pot is about 1/2 way round the dial (because the auto-bias function of the cathode biasing tends to 'fight' any change in bias. But when the depth pot is turned up it sounds good).
Strat with a Celestion G10 greenback (using 1 x 6L6 in the output section and 5U4G rectifier) soundbyte link here.
http://music-electronics-forum.com/attachments/12710d1297150553-super-ac4-g10-6l6-5u4g-lo-ht-trem.mp3
Another longer soundbyte of various trippy trem settings here (me accompanying myself)
http://www.nzguitars.com/forum/download/file.php?id=8343
« Last Edit: January 03, 2012, 01:28:58 pm by tubeswell »
« Reply #5 on: January 03, 2012, 01:53:47 pm »
Offline panhead
  • Play it like your hair's on fire
« Reply #6 on: January 05, 2012, 11:52:48 am »
The tremolo channel of the 18 watt Marshall is interesting. It adds a resistor between the plate and plate resistor of the gain stage and injects the plate signal from the oscillator between these resistors. It looks like the oscillator is modulating the plate voltage of the gain stage.
Panhead
