September 13, 2026, 09:09:25 pm
Hoffman Amps Forum image Author Topic: Reverb Circuit  (Read 6251 times)
Offline Jack1962
  • I love AMPS, Tube or SS
    • Latham Electronic Systems
Reverb Circuit
« on: January 02, 2012, 11:54:04 am »
What's Up
       I am wanting to add reverb to a Peavey Butcher , the original single channel butcher , I have 2 reverb tanks 1- Gribbs Manufacturing & Research Corporation (AO-23580-11) that I took from a Hammond L133 organ and 2- Accutronics (8EB2C18) that came from a Fender Blues Jr. what I need is a tube drive and recovery circuit that will work with either of these tanks . I have built the solid state circuit that goes with the Fender Bluse Jr. tank , however it requires a - and +15 volt power supply there is no voltage even colse to that in the Peavey Butcher.
                                                              Thanks For
                                                               Your Time
                                                              Jack Latham
Re: Reverb Circuit
« Reply #1 on: January 02, 2012, 12:28:43 pm »
You might want to check this out and see if there is anything you can use from this.
http://www.el34world.com/Forum/index.php?topic=7957.0
Offline Jack1962
Re: Reverb Circuit
« Reply #2 on: January 02, 2012, 12:44:59 pm »
Thanks Tubenit , I"ll give that a try
Re: Reverb Circuit
« Reply #3 on: January 02, 2012, 01:01:57 pm »
Your Accutronics unit has Input Impedance 800 Ohms, Output Impedance 2575 Ohms. It won't like any of the tube/transformer coupled drivers. You'll need a cap coupled driver such as in the last example in the thread tubenit posted. Or copy an old Magatone or Gibson cap coupled circuit.
Re: Reverb Circuit
« Reply #4 on: January 02, 2012, 01:36:36 pm »
Here is the schematic of an old Italian amp
GEM Super Deluxe Reverb 50 R
that don't use transformer in the reverb circuit
and uses a 6DR7 and a tube of the 12a*7 serie
Kagliostro
Offline Dave
Re: Reverb Circuit
« Reply #5 on: January 03, 2012, 06:38:10 am »
Ampeg had some really good reverb circuits that didn't use transformers.
Dave
Offline Jack1962
Re: Reverb Circuit
« Reply #6 on: January 03, 2012, 04:05:33 pm »
Thanks everyone for the great info
