September 14, 2026, 02:03:16 am
Hoffman Amps Forum image Author Topic: Lay down Fender PT mounting.  (Read 5175 times)
« on: January 03, 2012, 10:55:03 am »
Are PT's supposed to be mounted to the chassis with hex nuts between the PT and chassis (and bolted in with 4 more hex nuts), or do you take them off, mount the PT tight to the chassis with no air space (hex nut) between the PT and chassis with same hex nuts that were just taken off?
If the PT is mounted with the end bell tight to the chassis it seems the shielding would be better? If a hex nut is between the end bell and chassis it would allow a little air flow to get rid of some of the heat from inside the chassis?
I think either way will work, any thing I'm missing?
         Thanks,    Brad     :think1:
« Last Edit: January 03, 2012, 12:10:22 pm by Willabe »
Re: Lay down Fender PT mounting.
« Reply #1 on: January 03, 2012, 11:18:17 am »
That's what I do.
« Reply #2 on: January 03, 2012, 12:07:28 pm »
Thanks sluckey.
Thats the way I had it before I took it apart to re-build it. My BF FPR is like this too. I'll leave it like I had it.
                     Brad      :icon_biggrin:
« Last Edit: January 03, 2012, 12:11:09 pm by Willabe »
Offline LooseChange
    • Fix Your Darn Amps
« Reply #3 on: January 03, 2012, 12:22:05 pm »
I leave them on too. Too much trouble to remove them and I think it adds a bit of venting.
Call me Dan
www.fydamps.com
« Reply #4 on: January 03, 2012, 12:39:30 pm »
If the chassis is in a magnetic metal the montage with hex nuts
as to separate the transformer from the chassis, in some way,
will help to avoid the propagation of the magnetic field via the chassis,
sometime also little hex turrets can be seen in that place
if the transformer has also the lower end bell of course the magnetic field is more restrained
however, as you told, either way will work
Kagliostro
« Reply #5 on: January 03, 2012, 02:06:17 pm »
One of the transformer websites (Hammond maybe?) states "do not remove nuts". If I didn't have DL's disease, I'd remember which one for sure.  :icon_biggrin:
« Reply #6 on: January 03, 2012, 02:43:03 pm »
Thank you guys for the input.    :icon_biggrin:
I'm going to leave them on.
          Brad
Offline stingray_65
« Reply #7 on: January 04, 2012, 07:16:31 am »
Removing the nuts gives the cores a chance to shift.
all the quality xformers I've used have potting that holds them nicely during disassembly and installation, but what about down the road? if a mounting nut loosens?
Best to leave them be in my opinion.
Ray
