September 18, 2026, 06:24:53 pm
Hoffman Amps Forum image Author Topic: Question Re: Hoffman octal bias probes  (Read 6704 times)
Offline mindcrazedbanjo
« on: January 04, 2012, 07:51:16 am »
I've made 4 of these probes, when they are all in place and I'm checking one valve with my DMM, what do I do with the unconnected leads from the probes on the other valves? do I connect them together to complete the circuit? or is it ok to just let them hang loose unconnected?
Re: Question Re: Hoffman octal bias probes
« Reply #1 on: January 04, 2012, 09:13:03 am »
Don't connect them, only pay attention to the terminals
a little box with a rotary switch to commutate one at a time to the DMM will be of some practical use
Kagliostro
« Reply #2 on: January 04, 2012, 09:36:26 am »
thank you!
 "only pay attention to the terminals"
do you mean don't let the touch the chasis or something?
« Reply #3 on: January 04, 2012, 12:36:48 pm »
You must short the two banana plug terminals for each bias checker that doesn't have a DMM connected. Otherwise the cathodes of the unused tubes will be open and the tubes will be switched off. See this pic...
A better solution would be to permanently put a 1 ohm resistor across the terminals of each banana plug (4 resistors total). Now set your DMM to measure millivolts instead of measuring milliamps.
Offline LooseChange
    • Fix Your Darn Amps
« Reply #4 on: January 04, 2012, 12:50:24 pm »
Always thought about this... Why not install the one ohm resistor inside the probe. I find on occasion the meter fuse will blow when the amp is switched from Standby.
Call me Dan
www.fydamps.com
« Reply #5 on: January 04, 2012, 12:57:29 pm »
Someone sells an octal bias checker with the 1 ohm resistor mounted between the sockets. But it would be a lot of work to dissassemble the sockets to add the resistor. Much easier to put the resistor directly on the banana plug at this point.
« Reply #6 on: January 05, 2012, 06:57:04 am »
Thx again sluckey for having the patience, that about nails it for me.  :worthy1:
Offline LooseChange
« Reply #7 on: January 05, 2012, 10:42:05 am »
I made mine from Dougs design. I'm going to build another with the one ohm resister.
Call me Dan
www.fydamps.com
« Reply #8 on: January 05, 2012, 11:51:28 am »
yes, I was meaning that
but I remembered badly the schematic, I remembered the resistor was in, not out of the probe
SORRY
Kagliostro
