September 17, 2026, 03:30:25 am
Hoffman Amps Forum image Author Topic: TREBLE ATTENUATION by cap. shunt method at the power tubes plates  (Read 6402 times)
Offline Colas LeGrippa
  • MAKE LOVE NOT WAR
I'd like to know if someone here has ever tried to shunt the plates of the power tubes of a guitar amplifier to ground through a cap ( .022 or so ) in series with a variable pot, as a tone control ( or rather a treble cut control ).
Colaslalalalalala
P.S.: call me Alvin.
Re: TREBLE ATTENUATION by cap. shunt method at the power tubes plates
« Reply #1 on: January 18, 2012, 12:43:17 pm »
Hi Colas
No to ground not
this is similar but in order to simulate UL taps
http://locofonic.alphalink.com.au/valves.htm
Kagliostro
« Reply #2 on: January 18, 2012, 02:38:36 pm »
Cap at power plate is common in small 1 Watt radios.
At guitar amplifier powers, the _power_ in the cap and pot is significant, and burns-up the cap and pot in loud playing.
« Reply #3 on: January 18, 2012, 03:31:15 pm »
this seems to have something to do with your request
but I'm not able to give you any info
Kagliostro
  • MAKE LOVE NOT WAR
« Reply #4 on: January 18, 2012, 03:37:24 pm »
Grazie, fratello !
stratele52
  • Guest
« Reply #5 on: January 18, 2012, 03:57:03 pm »
Like PRR said in small radio.
Kagliostro shematic show a 50C5 tube , this is a 2.3 watts tube at maximum power output signal
  • MAKE LOVE NOT WAR
« Reply #6 on: January 18, 2012, 07:21:55 pm »
PRR, what about using two 630V caps in series, choosen according to the total capacitance needed ? Voltage up to 1200V, protecting the pot as well ? I like this arrangement because the tone is smoother. I read it has something to do with intermodulation cancelling ?
Colas
