September 17, 2026, 03:07:36 pm
Hoffman Amps Forum image Author Topic: Lowering B+  (Read 9974 times)
Offline dude
Lowering B+
« on: January 20, 2012, 03:33:27 pm »
I know there are several ways to lower B+ - Zeners, resistors, chokes, tubes etc.
I have a B+ of 454vdc, a little high for my GE gray plates for me at least, the screens have a 22K dropping R and are at 383v, OK
I'd like to get that 454v down a little, like 25v.  I know the screens will go down too but that's OK, 383 is on the high side anyway.
Would it best to use a resistor or a few 5 watt 15v Zeners in series?
Bridge rectifier, no tube and no CTR tap on the PT.
I was thinking about 5 watt, 2.7K.
al
Re: Lowering B+
« Reply #1 on: January 20, 2012, 07:08:34 pm »
Big zener can be expensive
here is one way with only one little zener
as you have no CT you must connect it between the negative of the bridge and ground
also you can try with a pair of big resistor between the transformer and the bridge
Kagliostro
« Last Edit: March 17, 2013, 02:21:42 am by kagliostro »
Offline dude
Re: Lowering B+
« Reply #2 on: January 20, 2012, 08:00:48 pm »
I don't have 15 watt 150 r so the Zener method looks good.
Can I use two 15 volt zeners (5 Watts) in series for 30v drop without making it variable?   don't have the components handy.
What is the "Tip 147" to pot and the arrows there, excuse my ignorance. I see this on some schematics
al
« Last Edit: January 20, 2012, 08:06:44 pm by dude »
Re: Lowering B+
« Reply #3 on: January 20, 2012, 08:05:56 pm »
Variable is only an option
The 15w 150R resistors where on that amp, in your amp the resistors must be calculated
the amplified zener doesn't need calculation
http://docs-europe.electrocomponents.com/webdocs/048e/0900766b8048e20a.pdf
http://it.mouser.com/ProductDetail/STMicroelectronics/TIP147/?qs=sGAEpiMZZMupZfs%2fwBb3DGpkiAxa96AGuVWL5L1RJ0Y%3d
Tip147 € 1.38 at Mouser
Kagliostro
« Last Edit: January 20, 2012, 08:10:22 pm by kagliostro »
Offline dude
Re: Lowering B+
« Reply #4 on: January 20, 2012, 08:56:05 pm »
Kagliostro
Thank you, same principle as Hall's Amplification
http://www.hallamplification.com/main.html?src=%2F#2,2
I only had 15v 5W Zeners so I put them in series off the negative side of the bridge to ground, dropped my B+ by 30v
Good enough for me at this point, the Halls' VVR lets you drop the voltage by a couple hundred volts, I guess if you want to really lower the output of the amp but the Mosfet they use is $12, lot more than $1.38.
al
stratele52
  • Guest
Re: Lowering B+
« Reply #5 on: January 21, 2012, 05:03:49 am »
I use often few 10 volts 5 watts zener with success. There are not expensive
Re: Lowering B+
« Reply #6 on: January 21, 2012, 12:46:05 pm »
My personal preference would be a dropping resistor.  Second choice, if there's room, a CT 12V bucking tranny -- a 6 or 12V drop in AC wall supply should work out ok.
stratele52
  • Guest
Re: Lowering B+
« Reply #7 on: January 21, 2012, 02:18:24 pm »
Dropping resistor will give ( to much ) sag.
A c.t 12 volts bucking tranny  ? ? More equipment on AC line outlet ! Not for me.
