August 29, 2026, 11:23:16 am
Hoffman Amps Forum image Author Topic: Unknow O.T. Check my maths.  (Read 4010 times)
Offline chocopower
« on: January 23, 2012, 08:26:55 pm »
Hi,
i have an old chasis with two 6V6, one 5Y3 and one 12AX7.
No marked speaker impedance, so..
I aplied 36,2 vAC to primary/plate taps.
I get 0,65 vAC in secondary.
so:
36,2/0,65 = 55,6923
55,6923 square = 3101 ohms
If a pair of 6V6 at 285vdc need to "see" 8k, i have a dilema:
With a 2 ohm load i get 6k2
With a 4 ohm load i get 12k4
the closer value i get is with the 2 ohm load (maths say 2,56ohms).
Close enough?
David
Re: Unknow O.T. Check my maths.
« Reply #1 on: January 26, 2012, 12:18:40 am »
Two-6V6 were often loaded in 10K.
This gives "3.2".
3.2 is another name for a 4 ohm speaker. In the old days, speaker impedance specification was not standardized. But DC resistance is clear and easy. A 3.2 DC ohm coil will be about 4 ohms around 400Hz, which is where speaker impedance specifications are now usually given.
Call it 4 ohms and play.
Offline chocopower
« Reply #2 on: January 26, 2012, 07:44:31 pm »
Cool.
Thanks!
David
