August 29, 2026, 11:24:23 am
Hoffman Amps Forum image Author Topic: Jensen F12NS field coil speaker in an instrument amp?  (Read 5800 times)
chuggy
  • Guest
« on: January 24, 2012, 09:58:26 pm »
Anyone offer thoughts or observations about using a Jensen F12NS field coil speaker in an instrument amp?
Markings are F12NS c5691 AO 21055 2S H3
I believe it came from a Hammond M2 organ.
Main use would be harmonica.
Thanks-
Offline bigsbybender
  • Hack Of All Trades
    • Tube Amp Gallery
Re: Jensen F12NS field coil speaker in an instrument amp?
« Reply #1 on: January 24, 2012, 10:34:30 pm »
It came from an instrument. If it's in good shape it's a good speaker. You would have to design the power-supply of the amp around feeding the field coil (it makes a choke). Keep the amp below 20 Watts, The M2 amp put a very clean and tame 11 Watts.
F12N: F= Field Coil  12= Size and N is Jensen Model (there are plenty of differing opinions of the actual watt rating).
AO21055 is the Hammond Part Number.  Odd that it doesn't have a 220XXX number as that is Jensen's manufacturing code.
j.
Open Minded But Fixed Bias
