August 29, 2026, 01:16:00 pm
Hoffman Amps Forum image Author Topic: TOS II Stand Alone Preamp - How to add a Balanced Output ?  (Read 5169 times)
« on: January 27, 2012, 05:37:38 pm »
I think that the TOS II is a very interesting amp and is since from TOS I that I've in mind the idea to build a stand alone preamp
from TOS I there were a lot of improvement and the TOS II is really something to be build
In this last time I'm collecting materials and infos as to build my U1 rack TOS II Preamp
thinking about the construction I was wondering to myself what about to add a balanced line output ?
it will be nice to go to a mixer or to a PC audio capture card directly from the preamp
as the output to FX Loop is from a cathode follower of V2b tube or of the mosfet (that is a good solution as to have a low output impedance)
I've think that the way to obtain a balanced output can be achieved by the use of a transformer like this
http://www.tube-town.net/ttstore/product_info.php/info/p3813_Audio-Uebertrager-1-1-2-1-fuer-Line-Signale-LTR-110.html
here a schematic about a balanced output with that transformer
but in my case the signal comes from the cathode instead than from the speaker output
also see this
http://www.jensen-transformers.com/as/as021.pdf
I'm not sure how to arrange this thing and need your help
THANKS in advance
Kagliostro
Re: TOS II Stand Alone Preamp - How to add a Balanced Output ?
« Reply #1 on: January 27, 2012, 10:10:15 pm »
Looks like it is from a high resistance potentiometer?
« Reply #2 on: January 28, 2012, 06:34:40 am »
Yes, you are right, I was considering the TOS II exit (the part that is between the cathode of V2b till the wiper of the pot) the same way of the part of the circuit that starts from the speaker intake till the wiper of the 5k pot
but sure the impedance will not be the same
Kagliostro
« Reply #3 on: January 29, 2012, 02:35:42 pm »
I've tried to solve the problem in this way
and need your councils about this solution
in green what I've do
I've think to use an ECC82 and in order to use both triodes the idea was try to use the second as substitute for the Mosfet
But I'm unsure about it as I don't want to alter the good tone of the TOS
Thanks for any help
Kagliostro
