August 29, 2026, 11:24:13 am
Hoffman Amps Forum image Author Topic: 220 Volt Main Transformer  (Read 5534 times)
« on: January 29, 2012, 05:31:52 pm »
This is a weird question that i already know the answer to but im getting this info from the seller of a Greek amp:
It goes like this: The PT requires a 220 volt main. He put a 110 power cord on the amp and plugged it into a 120 outlet
He says the amp has been running for 2 years but sounds like something is wrong with the sound
I said well of course. The secondary voltage needed to run the amp is virtually non exhistant. Like trying to run an 8 cylinder car on 1 cylinder
Anyway i was also thinking that there could be damage to the amp if the transistors are trying to draw current they cant get
What a weird call this was. I cant believe anyone that can change a power cord would not know this. I told my friend to stay away from it and keep his $400 dollars.
Offline stingray_65
Re: 220 Volt Main Transformer
« Reply #1 on: January 29, 2012, 05:57:38 pm »
I'd shy away from a SS amp any how :icon_biggrin:
But a SS amp the owner claims "sounds funny" well that just not a good thing.
Maybe you're loosing some information in translation.
my best info is Greece has 230V 50Hz mains
http://en.wikipedia.org/wiki/Mains_electricity_by_country
where did he get his 120 from?
« Last Edit: January 29, 2012, 06:06:07 pm by stingray_65 »
Offline Jack1962
  • I love AMPS, Tube or SS
    • Latham Electronic Systems
« Reply #2 on: January 29, 2012, 05:59:05 pm »
It's starving for volyage that's why it sounds wierd and yes it will damage the Solid State components.
« Reply #3 on: January 29, 2012, 07:35:34 pm »
Yes i miss typed. It is a 230V main. The amp is in Los Angeles. I suspected it would harm the components
« Reply #4 on: January 29, 2012, 08:22:32 pm »
Closer to two cylinders.
We had a 2-cyl Miata and it sure ran bad.
115V on 230V amp is not sure to do damage. I can think of a few designs would run "OK" at 1/4 power. Many more which would "sound funny".
« Reply #5 on: January 29, 2012, 08:39:00 pm »
What bothers me is why he did the 120 cord change when he has a step down transformer from 230 to 120.  It is a really rare amp and im stuck wondering if i should tell my friend to take the chance. Again there is no schematic or info to know what the secondary voltages would be for the rectifier bridge even if i changed out the transformer to a 120V Mains PT
I could quess and maybe safely be in the ballpark with 34-52VAC but quessing could be trouble . Not how i like to run my life or work
« Last Edit: January 29, 2012, 08:43:49 pm by plexi50 »
