September 17, 2026, 12:49:54 am
Hoffman Amps Forum image Author Topic: Hammond 125D Hookup for ECL84 Tubes  (Read 8014 times)
« on: February 05, 2012, 12:07:44 am »
Hi Guy's. Not sure what tabs to hookup the ECL84s to for a 8 and 4 ohm speaker, the only info i got is 15k:8ohm
http://www.hammondmfg.com/125.htm
I usually have 8 and 4ohm speaker connections in my builds, Also is the size of the speakers a problem to the small tubes as my speaker box has two 12" Mod 50's wired to 4 ohms. Thanks
Re: Hammond 125D Hookup for ECL84 Tubes
« Reply #1 on: February 05, 2012, 02:55:55 am »
15000 : 4ohm use 1 & 3
12800 : 8ohm is close enough to 15000 so use 4 & 6
--DL
« Reply #2 on: February 05, 2012, 01:06:46 pm »
Thanks DL  :icon_biggrin:
« Reply #3 on: February 19, 2012, 03:54:28 am »
Thanks guys,got that part sorted but if i was to have only one 4ohm speaker jack that would be easy but if i have 1x 4ohm and 1x 8ohm jack do i need to ground tag 4 as i have grounded tag 1 as you would.  :help: Any problems on the size of the speakers for these little TUBES ??? Thanks
« Reply #4 on: February 19, 2012, 04:15:57 am »
Not sure that I understand the question, but I run my SoLow Watt into one 8 ohm  Cannibis Rex  (Emminence speaker).
« Reply #5 on: February 19, 2012, 06:09:56 am »
no, you use one pair or the other pair exclusively - not both, unless you use a switch - simplest method would use DPDT sw - a 2A toggle or rotary will work fine. you need only one jack. still two holes in chassis though. use a 4TDP rotary and wire up 2, 4, 8, & 15ohm.
           4ohm
         1 x   x 3
 spk (-) x    x spk (+)
         4 x    x 6
            8ohm
--DL
« Reply #6 on: February 19, 2012, 01:02:48 pm »
Thanks DL, Tubenit, what i mean is does the actual size (8",10",12",15")speaker make the tubes work any harder to push the cone. Thanks
Offline birt
« Reply #7 on: February 19, 2012, 01:46:52 pm »
don't worry about that.
« Reply #8 on: February 19, 2012, 10:13:11 pm »
Cathode-bias amps, the tubes "work harder" when _silent_. They take-in all the power they will ever put out, waste most of it, but divert some power to the load and run cooler.
For a given acoustic level in the room, more/bigger speakers need _less_ power from the amp. Take a flea-watt amp. Connect it to a Full Stack (eight 10"s) and to a car door speaker. You can annoy the whole neighborhood with the Stack. Doing the same with the car speaker needs 10+ times the power.
« Reply #9 on: February 19, 2012, 11:52:22 pm »
Thanks guys  :icon_biggrin:
