August 29, 2026, 11:31:03 am
Hoffman Amps Forum image Author Topic: box of used tubes_Next Project  (Read 4660 times)
Offline ernest
« on: March 05, 2012, 06:35:21 pm »
I got a box of old tubes. I wanted to list some as I go through them.  Looking for some advice if any of these would be usable to audio amplifier applications.  I think lots are for TV but I did find 3 big light bulb type 5U4 tubes that will for sure be in a project....found a good 6v6 in there as well just not sure about most of these.
In my search for anything close to the #s 12ax7, 12au7, 12ay7, I was only able to find the following
TUBE    QTY
12BE6 - 3
12AV6 - 2
12BA6 - 4
12HL7
12CA5
I'll post some power tubes I found later and some more of these 9 pin tubes....
Re: box of used tubes_Next Project
« Reply #1 on: March 05, 2012, 06:58:34 pm »
12av6 is something like 1/2 12ax7 (+ there are two diode .... that you can ignore)
read also here
http://www.el34world.com/Forum/index.php?topic=11590.0
Kagliostro
« Last Edit: March 05, 2012, 07:03:01 pm by kagliostro »
Offline RicharD
    • Toxic Water
« Reply #3 on: March 05, 2012, 09:48:37 pm »
12BE6 - no, not easily.
12AV6 - yes - it's 1/2 12AX7 with 2 diodes - ignore the diodes. 12V version of 6AV6
12BA6 - remote cut-off - no, unless you're building a compressor.
12HL7 - video amp - yes, but likely more trouble than it's worth since you'd likely need a separate PS for the screens - a very high-slope tube. gm is 21K. very easily input overloaded.
12CA5 - yes, was designed for audio output stages in systems with low B+ supplies - 5W diss. should make 4-5W or so dependably in push-pull.
--DL
Offline ernest
« Reply #4 on: March 05, 2012, 10:15:17 pm »
looks like this guy is making something out of 12HL7.  looks cool
man, not seeing many of these listed out of what you guys posted in the other thread.   looks like the three 5U4 and one 6v6 cost me 60 bucks.  better make something of what I got.
« Reply #5 on: March 06, 2012, 12:58:50 am »
hit the local HAM shows. usually the larger ones still have a few tube sellers.
--DL
