September 16, 2026, 12:12:28 pm
Hoffman Amps Forum image Author Topic: SS choke  (Read 7540 times)
Offline Leevi
    • Rikstone
SS choke
« on: March 10, 2012, 03:36:10 pm »
Re: SS choke
« Reply #1 on: March 10, 2012, 03:54:43 pm »
No energy storage.
A real choke, if the load current is cut-off, the choke voltage will kick-up above the supply voltage.
This can only kick-up a couple volts, not even to the supply voltage.
It will kill ripple buzz. It may not have the guitar dynamics of a real choke.
2 bucks. Try it.
Offline Leevi
    • Rikstone
Re: SS choke
« Reply #2 on: March 10, 2012, 04:55:24 pm »
« Last Edit: March 10, 2012, 04:57:46 pm by Leevi »
Re: SS choke
« Reply #3 on: March 10, 2012, 05:36:57 pm »
Merlin explain how to calculate this kind of choke in his PS Book
Gyrator
Kagliostro
« Last Edit: March 10, 2012, 05:44:50 pm by kagliostro »
Offline jazbo8
Re: SS choke
« Reply #4 on: March 10, 2012, 08:04:30 pm »
I have not tried the gyrator yet, but it seems more suitable for plate load application, as PRR already hinted at, also see http://www.diyaudio.com/forums/tubes-valves/183476-electronic-choke-3.html#post2475782, in any case, nothing beats actual testing, has anyone tried using it as replacement choke in the power supply?
Jaz
Re: SS choke
« Reply #5 on: March 11, 2012, 09:15:37 pm »
This is new to me, but I googled this:  http://www.antiquewireless.org/otb/resto0504.htm
Seems to me this is not a choke but rather a voltage regulator. Voltage regulation will suppress ripple and other noise.  But as PRR points out, it lacks the reactance of a choke.
Offline Leevi
    • Rikstone
Re: SS choke
« Reply #6 on: March 12, 2012, 09:58:41 am »
I ordered couple of units, let's see how it works.
Anyway it's lighter and cheaper than a real choke.
/Leevi
Offline Leevi
    • Rikstone
Re: SS choke
« Reply #7 on: March 21, 2012, 01:03:13 pm »
I installed one board in an SE amp and placed it after the rectifier and first filter cap
and took B+ from the output of the device i.e. all current needed by the amp goes
through the "choke"-circuit.
I didn't notice any difference in the sound. Maybe it eliminated some hum.
Probably this is more beneficial in the amps where the hum level is higher.
/Leevi
Offline jazbo8
Re: SS choke
« Reply #8 on: March 21, 2012, 06:57:20 pm »
Try putting it (or them) on the plates of the pre-amp and PA driver, where it should have a more dramatic effect. Please keep us posted on your experiment.
Jaz
