August 29, 2026, 11:28:22 am
Hoffman Amps Forum image Author Topic: AC15 Build  (Read 20119 times)
Offline J Rindt
AC15 Build
« on: March 11, 2012, 03:23:38 pm »
Have any of you guys built an AC15 of some type or another.?
I have a Chassis and cabinet from an old Crate V18 that I thought I could use for an AC15 donor.
Do not think I have ever seen a layout for this amp, and was wondering what you guys did.
Not sure if anybody makes a turret board for this amp, or if it is more a matter of using turret strips to make the circuit.
Any ideas/help would be appreciated.
Thank You
Offline archaos
Re: AC15 Build
« Reply #1 on: March 11, 2012, 03:51:10 pm »
I've never built an AC15. Yet I've already built 2 x AC30s from scratch : one using an Hoffman board, the other à la JMI (turret strips).
If I were you, I'd build a turret board for that amp, it's far better : you can design the circuit like do Kevin O'Connor or Merlin Blencowe (with galactic grounds), & it's neat-looking (attached the guts of my 5E3).
Turret strips look vintage but are messy IMO.
I have stopped being surprised at the guitar player who spends $3,000 on the latest boutique amplifier, and plugs in his Mexican Stratocaster strung with light gauge strings through a Big Muff Pi fuzz pedal.
Mehr Licht !
Offline birt
Re: AC15 Build
« Reply #2 on: March 11, 2012, 03:58:55 pm »
this is an AC15 with a 12AX7 preamp and an EF86 preamp (EF86 values but i used a 6AU6)
« Last Edit: March 11, 2012, 06:18:39 pm by tubenit »
Re: AC15 Build
« Reply #4 on: March 11, 2012, 06:15:55 pm »
Re: AC15 Build
« Reply #5 on: March 11, 2012, 06:38:45 pm »
This looks like a decent layout.
Tubenit
Offline J Rindt
Re: AC15 Build
« Reply #6 on: March 11, 2012, 09:28:32 pm »
Thanks for the ideas/photos so far.
I can probably use some type of "generic" turret board. Something like you would see in a Hiwatt.....kind of long and narrow.
Thanks Again
Re: AC15 Build
« Reply #7 on: March 13, 2012, 05:44:03 am »
I drew this up thinking it could be an interesting idea.  You'd have an AC15 tone using a 5879 (less microphonic) instead of a EF86.
AND you could switch in a HoSo56 tone.   It also has switchable active FX loop.
Could be a cool amp?  Not sure about the coupling caps after the LTPI. I put down .047 but would probably build it myself using .033.
« Last Edit: March 13, 2012, 07:08:04 am by tubenit »
Offline moonbird
Re: AC15 Build
« Reply #8 on: April 16, 2012, 12:43:18 am »
Tubenit -
A very interesting spin on the AC15. What PT voltage does this design want? I am looking for AC-30 kind of chime and articulation for country tunes. Probably looking for a poor man's top-boost circuit I suppose. Will this design deliver that you think or could something be added?? If I wanted reverb, I presume I could add your "single 12AX7" verb design from the 56T at the effects loop. Thanks very much for posting this!!
Re: AC15 Build
« Reply #9 on: April 16, 2012, 05:17:33 am »
If I were building it, I'd want a PT that was 275-0-275 and had 150ma.  You might be able to use a 300-0-300 with a 5Y3GT?
Just check the tube data for an EL84
Offline J Rindt
Re: AC15 Build
« Reply #10 on: April 16, 2012, 11:36:53 am »
Tubenit.....
In your previous 2 links, are they of the same schem.? I ask, because I cannot open the second schem that uses the Microsoft Schedule Plus program.
Thank You
Offline balcorn80
Re: AC15 Build
« Reply #11 on: April 16, 2012, 01:22:52 pm »
Tubenit.....
Thank You
Download Jschem or PCBExpress to open the .sch files. I just learned about these programs last week, and have already started putting my hand-drawn schematics into electronic form(even I have a hard time reading my chicken scratch) plus it makes it easy to make any changes between your paper/electronic schematic and what actually worked for you. Just a suggestion.
http://dhost.info/jschem/
http://www.expresspcb.com/expresspcbhtm/Download.htm
Offline J Rindt
Re: AC15 Build
« Reply #12 on: April 16, 2012, 02:10:14 pm »
10-4
Thank You
