September 14, 2026, 04:58:41 pm
Hoffman Amps Forum image Author Topic: 5F6a preamp to Sunn PI?  (Read 4316 times)
Offline firemedic
« on: March 13, 2012, 12:48:37 pm »
Would there be some sort of massive impedance mismatch or other problem with a 5F6a channel feeding a Sunn-style pentode/cathodyne?
An anode follower normally feeds the pentode; would a cathode follower work all right?
Re: 5F6a preamp to Sunn PI?
« Reply #1 on: March 13, 2012, 10:35:32 pm »
5F6a delivers about 2V to the lo-gain power stage.
Sunn power stage needs less than 1V, maybe under 0.5V.
It can work, Gain will be high, layout may be critical.
Why not a dual-triode driver instead of the scarce 7199 pentode-triode?
Offline firemedic
« Reply #2 on: March 14, 2012, 10:18:20 am »
It's really a 5879 feeding a 12AU7 triode cathodyne.
There's also a 1M master volume pot between the stack & the pentode, so I'll be able to get the PI input about right with the MV knob I think.
I have been juggling values all over this bass amp to get voltages & gain where I want them, & without an o-scope or real knowledge it's a fairly tedious trial & error slog.
One channel is an Ampeg B25b which sounds about dialed in, with stock values, and I'm finishing up the 2nd channel. It started life as a Weber 6S100 modified for bass but it's not working out as such.
See the "bass amp suggestions" thread to see the 4-month+ deal I'm dealin' in.
