September 14, 2026, 11:16:52 pm
Hoffman Amps Forum image Author Topic: thermistor question  (Read 4258 times)
Offline worth
thermistor question
« on: March 16, 2012, 11:59:23 am »
Looking at this schematic, there is a thermistor , (Thm1) in the upper left corner between the power receptical and the power switch. Someone has jumpered this thermistor with a wire. Could that cause a problem ? There is quite a hum in the amp.
« Last Edit: March 16, 2012, 12:06:15 pm by worth »
Offline phsyconoodler
Re: thermistor question
« Reply #1 on: March 16, 2012, 01:05:27 pm »
That won't cause a hum.You have other issues.Find those first and then get a new thermistor.
Offline worth
« Reply #2 on: March 16, 2012, 03:27:47 pm »
Turns out R11 , (4.7 ohm at bottom of schem ) was burned , breaking a signal ground.
