September 15, 2026, 11:43:08 pm
Hoffman Amps Forum image Author Topic: Fixed Voltage VVR  (Read 4423 times)
Fixed Voltage VVR
« on: March 20, 2012, 03:32:51 am »
Hi guys, This may be trying to fix something that aint broke. I was unable to find a Fixed 250v regulator that i could use to drop the voltage for the ECL84 tubes.
The vvr was the best way to go and works well.
I measured the ohms on the two sides of the pot G-Z 426k and G-X 743k.
Has anyone modded a VVR to have it as a fixed voltage and can the pot just be replaced with resistors as shown Thanks
Offline FYL
Re: Fixed Voltage VVR
« Reply #1 on: March 20, 2012, 03:45:19 am »
Resistors are OK.
« Reply #2 on: March 20, 2012, 04:11:46 am »
I haven't do but certainly you can use a VVR circuit that way
you can use fixed resistors or a trimmer as to substitute the pot
an alternative is to use a Zener Follower circuit
this will give a "stabilized" voltage, but is it necessary ?
Kagliostro
