September 17, 2026, 10:40:19 pm
Hoffman Amps Forum image Author Topic: Tweaking my amp for more Low-Mids  (Read 4967 times)
Offline TurboGuitarMelton
« on: March 22, 2012, 01:10:02 pm »
Hey guys I have a Laney TT100H and i was wondering what i could do to tweak the electronics to give more low-mids in my sound?  :think1:
Here is the schematic diagram! its also attached to the post.
http://musickoncept.free.fr/Pdf/Audio%20-%20Amplifier%20-%20Guitar%20-%20Laney%20Schematics%20Tt100H.pdf
Any help would REALLY be appreciated!
Thaanks,
Daniel
Re: Tweaking my amp for more Low-Mids
« Reply #1 on: March 22, 2012, 01:43:02 pm »
In which of the 3 channels do you want more mids?  E.g.: Channel A (FMV), things to try:  decrease slope resistor R1 to 68K or 51K; increase treble cap C1 to 300pF or 500pF; increase mid pot to 50K.
« Reply #2 on: March 22, 2012, 02:23:51 pm »
I was wanting to do the third channel(C). Which cap/resistors specifically in channel three(C) would i need to change the values of? Also which one do you think would have the greatest effect? Thanks for the help!  I'm fairly new to this stuff.
« Reply #3 on: March 22, 2012, 03:44:34 pm »
Increase C8/22n which is .022uF/400v to .047uf/400V which is also 47n/400v. This will give you more bass to dial in which will also affect your low mids on your bass & mid pots when you dial things in.
Next is to directly increase the overall available mids by increasing the midrange potentiometer VR10 which is a 22k linear pot to a 50k linear pot. !00k can be used if that's all you have but will not be all that much more mids that you'll get over the 50k one.
3rd & last thing if you still feel something even more is necessary/wanted is to increase the C9 22n/400 cap like the other using a 47n/.047uF cap here.
« Reply #4 on: March 22, 2012, 04:20:05 pm »
Thank you guys so much! Ill let you know how it turns out when i do it!
Offline Colas LeGrippa
  • MAKE LOVE NOT WAR
« Reply #5 on: March 22, 2012, 07:01:57 pm »
even if you change a cap to a lower value, it won't remove highs, it will give you more bottom end and mayl affect the balance of the amp, sometimes leaving a ''hole'' in the frequency spectrum: lots of highs, lots of bottom, lack of mids
P.S.: call me Alvin.
Offline The_Gaz
« Reply #6 on: March 23, 2012, 01:08:19 am »
First thing I'd do is reduce C9 (mid cap) to 15n, which will technically increase low mids. Easy to see on TSC.
