August 29, 2026, 11:24:08 am
Hoffman Amps Forum image Author Topic: Help Confirm OT wiring on Classictone JTM45 OT  (Read 4548 times)
Offline Tsquared
  • Harnessing wild electrons
« on: March 24, 2012, 04:13:34 pm »
I think I may have wired my OT wrong... SO
Which is the center tap on the primary? I'm not sure what the black dot next to the black primary lead means in the wiring spec sheet from Magnetic Components, but I assumed the center tap was the brown wire for some reason.
 Here is a link to the diagram: http://www.classictone.net/40-18039.pdf
Can anybody confirm the correct wiring, PLEASE??? I'm starting to go nuts!
Tod
Re: Help Confirm OT wiring on Classictone JTM45 OT
« Reply #1 on: March 24, 2012, 05:04:49 pm »
Hi T2, Black wire, black dot to me is the more - side(i connect this to the power tube that is connected to the second side of the PI triode) Brown is CT (usually connected to A node) and Red more + side ( connected to the power tube that is connected to the first side of the PI triode) and Yellow is your -,ground for the speaker.
I don't know if the two PI triodes are split into + and - but this is how i see it. Thanks
« Reply #2 on: March 24, 2012, 07:17:56 pm »
It is. for that OT.
The black dots (notice one by the yel secondary wire too) are phase indicators. IE, when the AC signal on the black primary is swinging positive, the AC signal on the yellow secondary will be swinging positive also. IOW the signal on the yellow wire is in phase with the signal on the black wire.
