August 29, 2026, 11:24:23 am
Hoffman Amps Forum image Author Topic: Best type of wire for ac into amp?  (Read 5657 times)
Offline frank57
« on: April 03, 2012, 12:59:46 pm »
What's the best type of wire to use for the ac plug going into the amp?
This one has stranded 1015 22 awg tew  600v.
They didn't twist them and they're cut a little short for me to unsolder and twist.
I was thinking 18 awg teflon?
Offline Tsquared
  • Harnessing wild electrons
Re: Best type of wire for ac into amp?
« Reply #1 on: April 03, 2012, 01:41:31 pm »
Frank,
If you're going to wire it yourself, why not use a decent 16 guage with a decent black neoprene type jacket? You don't need teflon.  But I wouldn't go smaller that 16 if the cord is longish. And make sure you put a proper grommet/strain relief.
Why not just use a IEC style plug.  It may be easier to cut those out of the chassis than a C shaped hole for the strain relief. I use a dremel with a cutoff wheel to do the rectangular cutout for my IEC recepticles and it works great.
Tod
Offline LooseChange
    • Fix Your Darn Amps
« Reply #2 on: April 03, 2012, 04:35:22 pm »
Most power cords are 18ga. That's plenty.
Call me Dan
www.fydamps.com
Offline frank57
« Reply #3 on: April 04, 2012, 11:23:07 am »
It's for the wire attached to the iec receptacle and the fuse going to the mains.
This old photo shows the wires.
I have a power board above it right now, so I'd like
e to twist them and move them off to the edge.
« Reply #4 on: April 04, 2012, 11:31:35 am »
Just use the same size as the primary wires coming out of the PT.
Offline frank57
« Reply #5 on: April 04, 2012, 01:28:18 pm »
I have some 22 awg teflon.Would that be good or should I use the exact same 22awg ul1015 600v that 's in there now?
« Reply #6 on: April 05, 2012, 05:37:05 pm »
Frank - Sluckey's response is a good one. I would use 18ga stranded and insulated wire. I usually have some remnants of that, when ever I trim a cord I keep the wire I snipped off in a ziplock with all the rest of them. I'm sure many of the guys here do similar things. But if it's in the power section I don't think I would go lower than 18ga. That's MHO YMMV.
Cheers
Offline frank57
« Reply #7 on: April 06, 2012, 07:26:03 am »
It's not to replace the plug but the wires attached to the 3 prongs inside the amp.
They used  stranded 1015 22 awg tew  600v.I can't twist it they cut it short.
Would teflon on the hoffman supplies be a good substitute or stick with the same wire?
I can't seem to find it in small amounts anywhere.
« Reply #8 on: April 06, 2012, 08:33:40 am »
For combo amps, I go to the local electrical wholesaler and buy a 3-6 metre (yard) mains extn lead and chop the female plug off. These leads are cheaper than what you can make out of separate components, and the plugs are sealed.  For head amps, I use an IEC socket and lead
