September 14, 2026, 05:11:55 am
Hoffman Amps Forum image Author Topic: SVT-CL volume fluctuates while using -15dB input.  (Read 4070 times)
Offline L_Roy_Saint
« on: April 04, 2012, 10:49:15 am »
SVT-CL volume fluctuates while using -15dB input.  All tubes test ok.  Volume will either start at a lower volume and sudedenly jump after 20-30 minutes use or start high and drop by about half.  This repeats itself.  Sound familiar?
I saw this in a cartoon once, I think I can do it.
Re: SVT-CL volume fluctuates while using -15dB input.
« Reply #1 on: April 06, 2012, 12:38:02 am »
Dirty jack, bad solder joints on jack and resistors, bad resistors.
Offline L_Roy_Saint
« Reply #2 on: April 06, 2012, 05:58:52 am »
Thank you.  I will check it out.
Offline L_Roy_Saint
« Reply #3 on: April 25, 2012, 06:30:26 am »
SUCCESS!
The problem was the 0db input jack.  The two leads which make contact when the jack is vacant weren't making proper contact, causing the preamp to operate in unbuffered mode.  I cleaned the contacts thoroughly with alcohol and verified their continuity with a DMM.
While I had the preamp out of the unit I noticed alot of flux on the bottom of the pcb.  I cleaned this as well.
