August 29, 2026, 11:24:09 am
Hoffman Amps Forum image Author Topic: Ampeg J12R re-issue runs zero bias?  (Read 5448 times)
Offline Tiny_Daddy
  • Get your Amp N Gear!
« on: April 07, 2012, 04:46:36 pm »
This one came into the shop with cooked tubes. Replaced tubes and expected cathode bias, nut NO! There is no bias. Don't have a schematic so I traced the cathode: connects to the grounded filament circuit. Grid measures 240K to ground, verified that too. Anyone else seen this?
Re: Ampeg J12R re-issue runs zero bias?
« Reply #1 on: April 07, 2012, 10:31:56 pm »
Aint right.
Pull tubes, power-up, quickly look for negative voltage at grids.
If the cathodes are hard-grounded, yet grids are at zero, suspect a short in the bias supply.
« Reply #2 on: April 07, 2012, 10:37:16 pm »
On the original...
http://www.el34world.com/charts/Schematics/files/ampeg/Ampeg_J12R_.pdf
...cathode connects to heater circuit which is NOT grounded.
There should be a 10 Watt resistor; maybe easy to find.
Heater-wiring short to ground or shorted cathode-cap on that 10W resistor?
Offline Tiny_Daddy
« Reply #3 on: April 08, 2012, 08:05:01 am »
Nope, no 10 watt resistor. I have traced the grids and cathodes to a star ground. No negative voltage on grid circuit, just zero volts. Hard to believe. I plan to install cathode bias.
Offline LooseChange
    • Fix Your Darn Amps
« Reply #4 on: April 08, 2012, 06:51:47 pm »
Are you implying it works with zero bias voltage?
Sure looks like cathode bias on the schematic.
Call me Dan
www.fydamps.com
Offline Tiny_Daddy
« Reply #5 on: April 08, 2012, 07:19:30 pm »
Looks like I was wrong, cathode not going to ground. More on this later.... Wish I had a schematic.
« Last Edit: April 09, 2012, 07:08:27 am by Tiny_Daddy »
Offline Tiny_Daddy
Re: Ampeg J12R re-issue resolved!
« Reply #6 on: April 14, 2012, 08:13:33 pm »
Problem was the tubes were cathode biased with a 120 ohms 5 watt resistor and would try to draw 60mA each! Since I have to install and guarantee the tubes, I find 220 ohms gives more reasonable bias and the amp still has plenty of power. This re-issue does not match the old schematic and has an op-amp and a pair of 12AX7.
