August 29, 2026, 11:29:19 am
Hoffman Amps Forum image Author Topic: On-none-On  (Read 4652 times)
Offline J Rindt
On-none-On
« on: April 17, 2012, 01:25:44 pm »
Pulled one of these switches out of my bin.
With a meter, I cannot tell the difference between this and a "regular" SPDT switch.
Toggle up and one lead has continuity to the center conductor, toggle down and you have the opposite condition.
Obviously I am missing something. So what is a On-none-On switch.?
Thank You
Re: On-none-On
« Reply #1 on: April 17, 2012, 01:42:23 pm »
Check this out:  http://www.nkkswitches.com/pdf/M2toggles.pdf
A double pole SW may have a Center OFF position; if so, then it's ON -OFF- ON.  If not, then it's ON -None- ON: indicating that there's No Center position.
EDIT:  There are also DPDT Center ON switches:  http://www.1728.org/guitar.htm
« Last Edit: April 17, 2012, 01:54:15 pm by jjasilli »
Offline J Rindt
Re: On-none-On
« Reply #2 on: April 17, 2012, 04:35:08 pm »
OK....sorry.
Did not realize it was a literal term.
Guess I am just use to a SPDT not having a center position unless it says OFF.
My mistake.
Thank You
