September 17, 2026, 05:28:23 am
Hoffman Amps Forum image Author Topic: 65 amps...  (Read 18980 times)
Offline bruno
  • got to love that glow
65 amps...
« on: May 02, 2012, 04:07:13 am »
Recently got a hold of new 65 amps ventura, which I'm enjoying. Obviously had to take a pick inside, since it's sort of a simplified soho.
I found out that 65 uses a lot of details to limit bass and most likely blocking distortion, right after the input there is a sort of high pass filter formed by a 0,1uf cap and a 1M resistor.
The cathode of the first ef86 stage also has a sort of treble boosting cap. Along with some other cool details, which give the amp a characteristic tone which some of you seem to have picked up from the youtube videos of the soho.
Re: 65 amps...
« Reply #1 on: May 02, 2012, 12:14:34 pm »
2Hz. Does not shave any bass. More likely a defense against pedals with DC leakage.
Re: 65 amps...
« Reply #2 on: May 02, 2012, 12:35:02 pm »
The .1 cap... would that be in series with the 33k grid stop going into V1, in parallel with it, or going to ground?
I run cheap pedals.
Offline bruno
Re: 65 amps...
« Reply #3 on: May 02, 2012, 02:55:45 pm »
Yes that is true the 0.1uf wouldn't shave enough bass.
Right at the input you have a 1M resistor to ground, then the 0,1uf cap, then another 1M resistor to ground, and then the 33k grid stopper in series with the cap.
Across the input jack there is also what appears to be a very small blue component, which looks like a cap, but I haven't been able to understand how it's wired, or what it does.
Re: 65 amps...
« Reply #4 on: May 02, 2012, 03:20:36 pm »
Cool, thanks.
Offline bruno
Re: 65 amps...
« Reply #5 on: May 02, 2012, 03:37:08 pm »
Offline seedlings
Re: 65 amps...
« Reply #6 on: May 04, 2012, 09:16:40 am »
Thanks for the pic!  Always nice to have a look inside for curiosity sake.
CHAD
Re: 65 amps...
« Reply #7 on: May 04, 2012, 10:07:37 am »
Re: 65 amps...
« Reply #8 on: May 04, 2012, 03:50:23 pm »
If the chassis wasn't being used at all as the amp's circuit ground, I'd think the blue component was a cap from the isolated jack ground to the chassis to shunt RF interference.
But, I think I see other places where there are chassis bolts used as grounding points. If that's the case, the theory above doesn't work. In other words, it relies on a circuit that keeps chassis ground (including the ground wire of the power cord) isolated from signal ground (all other grounds used by the amp/power supply circuitry).
Offline bruno
Re: 65 amps...
« Reply #9 on: May 04, 2012, 05:51:43 pm »
I believe that's precisely what is happening, however there are indeed bolts being used as chassis ground.
Offline clyde
Re: 65 amps...
« Reply #10 on: May 04, 2012, 10:38:43 pm »
What is the IC on the chassis?
Offline Geezer
Re: 65 amps...
« Reply #11 on: May 05, 2012, 06:19:32 am »
Power-scaling circuit
G
Re: 65 amps...
« Reply #12 on: May 05, 2012, 10:50:57 am »
But where's the control pot for it?     :dontknow:
The mosfet and pot should be close together for stability.
                     Brad
Offline Geezer
Re: 65 amps...
« Reply #13 on: May 05, 2012, 11:44:24 am »
                     Brad
http://www.65amps.com/the-ventura.html#7
The "Master" is actually "Master Voltage" (VVR)
Don't know how they get away with the distance.........
Re: 65 amps...
« Reply #14 on: May 05, 2012, 12:06:00 pm »
Huh. I guess it's working for them?
                     Brad     :think1:
Offline TubeGeek
    • Glacier Amps
Re: 65 amps...
« Reply #15 on: May 05, 2012, 12:15:11 pm »
I have had a few of 65's amps come across my bench.
Here is a pic of the component in question on the input jack...looks like a cap to me.  I zoomed in on it and it looks like it connects to a piece of brass which probably connects to the chassis.
This is from an Empire.
« Last Edit: May 05, 2012, 12:21:41 pm by TubeGeek »
Re: 65 amps...
« Reply #16 on: May 05, 2012, 12:26:18 pm »
Now that amp looks like the VVR mosfet is pretty close to it's control pot?
                           Brad     :think1:
Re: 65 amps...
« Reply #17 on: May 05, 2012, 11:59:13 pm »
> a circuit that keeps chassis ground ...isolated from signal ground
You can float the input jack and have the main audio-signal ground at the other end of the amp. In that case it is often done to use a small cap to shunt any RF at the input jack to chassis rather than make it flow all the way through the amp's signal ground system.
Offline Quatro
Re: 65 amps...
« Reply #18 on: May 06, 2012, 01:38:24 am »
What's an optimal value to get the job done?
Re: 65 amps...
« Reply #19 on: May 06, 2012, 04:25:00 am »
Probably something on the order of 0.001uF to 0.01uF.
Remember, this is not going from hot to ground, but from the ground lugs of an isolated jack to the chassis.
« Last Edit: May 06, 2012, 03:10:52 pm by HotBluePlates »
Offline 6bq5
Re: 65 amps...
« Reply #20 on: May 06, 2012, 10:49:44 am »
the .1uf on the input is to block dc that develops when you lower the power scaling to max.   if you don't have it there the guitar vol pot will get scratchy from the dc developed on the input.    usually happens if you scale to go below 60v or so on the plates.   65amps uses dana hall's vvr circuit.     rh
Re: 65 amps...
« Reply #21 on: May 06, 2012, 03:09:49 pm »
The cap I was talking about is not in series with the signal, like a blocking cap. It's shunting from a ground terminal to chassis ground.
« Last Edit: May 13, 2012, 03:20:08 pm by HotBluePlates »
Offline bruno
Re: 65 amps...
« Reply #22 on: May 08, 2012, 07:23:21 am »
I drawed a little bit of the preamp too. It's an interesting amp, but nothing overwhelming.
Offline proaudioguy
Re: 65 amps...
« Reply #23 on: May 13, 2012, 02:06:07 pm »
What you describe here (isolating signal and chassis ground) is the only correct way to handle audio equipment shielding and grounding. The manufacturers in my industry that have tied audio signal ground to chassis ground have what is known as the pin 1 problem.  What should be draining off to earth ends up in the audio circuit.  Google is your friend here.
http://pin1problem.com/
http://www.rane.com/note165.html
Re: 65 amps...
« Reply #24 on: May 13, 2012, 03:22:21 pm »
The saving grace is that while pro audio has a large number of interconnected pieces of gear and maybe miles of mic cabling run through the walls, most often we just have a guitar and amp.
Offline bnwitt
  • Crankin' out the tone.
Re: 65 amps...
« Reply #25 on: May 13, 2012, 08:05:57 pm »
Yek! Terminal strips.  I thought Leo and Mr. Marshall brought us out of the stone age. :l2:
Offline SLW
    • diyeffects.com
Re: 65 amps...
« Reply #26 on: May 20, 2012, 09:23:41 pm »
I would like to see your drawing of the circuit.  It is always fun to see how things are done.
stompbox pcb's
my blog
Offline fuzz
Re: 65 amps...
« Reply #27 on: November 24, 2012, 03:00:02 pm »
nothing new about this ventura ?
Offline neon333
Re: 65 amps...
« Reply #28 on: November 24, 2012, 04:15:11 pm »
So what is different between the Ventura and the SoHo? Never seen the inside of either.
Offline phsyconoodler
Re: 65 amps...
« Reply #29 on: November 25, 2012, 06:24:20 pm »
Indeed. Seems he uses terminal strips so people have more difficulty reverse enginbeering his circuit.They are all plagerized anyway,but he has a couple of tricks here and there to make them sweet sounding and he likely wants to keep it to himself while he's riding the wave.
  They go for a pretty penny,for a mediocre wiring job.It's all about being in the right place at the right time like Dr. Z.Nothing special about either amp,just solid build and they sound good.
  Pretty much like most of the builders on this forum.
Offline darryl
    • ValveTone Amplification
Re: 65 amps...
« Reply #30 on: November 25, 2012, 07:11:45 pm »
. . . but there are still some of us who prefer to remain in the tagstrip stone age.  :icon_biggrin:
Offline bigsbybender
  • Hack Of All Trades
    • Tube Amp Gallery
Re: 65 amps...
« Reply #31 on: November 28, 2012, 01:52:17 am »
I remember him posting a lot on another forum when early on when he started this company... He's just like one of us but he got lucky. I recall him being having good manners online and being helpful toward others.
Open Minded But Fixed Bias
