September 18, 2026, 03:03:37 pm
Hoffman Amps Forum image Author Topic: Old 1967 Davoli Band 4 italian amp - Which amp is this ?  (Read 8980 times)
« on: May 14, 2012, 06:08:12 pm »
Some time ago I got an old Davoli Band 4 amp
there is a SS preamp (a very small reverb tank is present) with 4 inputs and a tube PA
only today I was able to get the schematic of the preamp and I'm confused
is this a guitar amp ? I doubt
looking to the input I'm not able to understand if this can be used as is as to amplify a guitar
the fact that it has a SS circuit (I understand near nothing about SS), the tone control at the input and the fact that input is rated at 30-800ohm confuse me a lot
please can you give me help ?
Thanks in advance
Kagliostro
« Last Edit: May 14, 2012, 06:10:34 pm by kagliostro »
Online sluckey
Re: Old 1967 Davoli Band 4 italian amp - Which amp is this ?
« Reply #1 on: May 14, 2012, 06:48:51 pm »
It looks like a 4 input Low Z microphone mixer with reverb.
Offline birt
« Reply #2 on: May 15, 2012, 03:34:40 am »
since the input is already solid state there is a big chance the 'modern' mics at that time were already mostly low impedance. this suggests you have mic inputs there. there were lots of small mixers that had a tiny reverb tank, in most i've seen the reverb was on all channels. it's called 'band' and has a PA in the same unit. so its probably made to amplify a band without too much extra gear. 4 mics was plenty (the Beatles could do it). Set the levels, rock the local club.
« Reply #3 on: May 15, 2012, 08:14:51 am »
Thanks Sluckey & Birt
I'm not sure about what to do
may be I change the preamp and I'll obtain a guitar amp
I don't think I can use this preamp with some mod as a guitar preamp
Kagliostro
Offline birt
« Reply #4 on: May 15, 2012, 11:08:20 am »
it looks like the impedance is set by the resistor values in the passive network of a single channel before it gets mixed. so if you play around with these values (make them higher go to 1M pots and get the fixed resistor values in the same ballpark. i'm sure someone can calculate all this but i'm not that someone. i just try things) you can make it suitable for guitar. or replace those passive networks with something like the ROG fetzer valve. that will probably give you a nice bit of gain on tap and you can still use the reverb. ( http://www.runoffgroove.com/fetzervalve.html )
« Reply #5 on: May 15, 2012, 12:43:21 pm »
Thanks Birt
for your councils and for the Fetzer link, I didn't know that
Kagliostro
« Reply #6 on: May 15, 2012, 03:08:58 pm »
Just curious, Is this thread going to be moved to the SS section?
May be, the amp is a tube amp, but the preamp is SS
Kagliostro
« Reply #7 on: May 17, 2012, 08:13:42 am »
No I haven't considered any mod to the PA
I'm interested only to mod the preamp as to use the amp with guitar instead of microphones
may be I decide to clone the preamp of the Davoli Show II or, may be, to build a tube preamp
Kagliostro
« Last Edit: May 17, 2012, 08:17:12 am by kagliostro »
« Reply #8 on: May 17, 2012, 11:58:19 pm »
You want just one guitar input, correct?
« Reply #9 on: May 18, 2012, 03:38:51 am »
Yes that I want !
Many Thanks PRR
Kagliostro
